MC2 Project - Chassis prep
DeLaSoul
  james said:
:mrgreen:
that would be a cool idea BUT WHY!
I was looking to do a wiring tuck on the engine while everything is out and found the rywire web site - but I'm b****red if I'm paying $1000 for a wiring harness on a cool quick disconnect. £70 for the connector, some hours swearing at a soldering iron and jobs done. I have to rewire the harness into the engine bay anyway as the wires had to be moved from their original locations to clear the roll cage. While I'm at it, I can remove all the bits from the harness that's no longer required like central locking, electric windows, sunroof, AC etc. etc.
  WilkesyMB6 said:
If your doing it yourself and have the ability why the flip not, fair play to you!
See what happens what I try and start the car and the headlights just flash lol. Should be okay, just a lot of wires.
  james said:
Label everything but u allready know that
I did forget to when I took the harness off the engine, took me a while a day later to label up all the plugs. I will make up the loom from the engine to the ECU with some slack, cut 1 wire at time and fit the plug, then put the engine back in the car, simples
  UnicyclingTom said:
Anything off of a jet plane is bound to make the car go faster :D:D
oh yes :lol:
