MC2 Project - Chassis prep
DeLaSoul
Quick update, been away in New Zealand with work for a few weeks so no solid progress on the car but parts arrived while i was away so I got a few small jobs done on Sunday.
Fuel System - finally bought all the fittings and hose to do the fuel system.  Spent about 2 hours routing and plumbing it in but will need a bit more work.  At least all the hoses are now cut to length.
Fuel pickup, to filter (which will have a top cover), to the bulkhead.  Return is attached and back to tank.  Finally the vent is sent straight up to the cage, looped back and needs a bulkhead fitting putting in to vent to the outside of the car in a "dead air zone"
5OdMgKFojFEjkwaWiONRRdoZBNIsNnkYFY5mCXy0
iNFHpTl1b70KFVScVJKp_xlLS6i756Ct5EJKKZIn
Fuel lines from the rail to the fuel pressure regulator and then back along the bulkhead.  Excuse the wiring, need to tidy up the routing
CtGcHHEKuvrx-rxxlk76xPSF3dTEXzIPevsvvzqk
1VOOi0NF5sHN6-lYPKIG8NyxprBLW6UFPUKQ-2-d
  • Like 4
  • 2 months later...
Small update, I've been away in NZ several times with work and now home and moving house.
Started to make a new centre console mould tool.  Old centre console was good, but with the harness done up tight I couldn't reach the switches so started again!
Cardboard and paper model to test fit, then wooden former.
zIMXo00R206qSCZmLIqFiQY_g1ZhU0f_dr7dcvbv
J2gA3kCwo0IVPhW8mMNbQkqF_2ldw3LOls5ADUxJol4gSZkQViDCsnwfZREf3-98KrfOkznSILxhda7vfWXPcQNxMjrPtQVI450dXjoX01svDZcJiMyMyRwMTDXqiMF2HccovTRSnjfhiE_c1AW6cH9X3yO6tJqu94dYSNt2j-8CgNJsVZPVha0MQZRJoV8gFPNbw-CSgUFdWjKzhsI_Haw4q2Uo6mTqwueofSdN0bR7gGog8sIYJ_BIwVn-auvyj6o067Mk64gprOuDt59_ykPTLBVkFbdOJj-1XT5MTXZmJQH4oIpmGPS0lJeP8VH2o5UxQYhdbA8-chfOmUrrkyYUDZDFv5PzmUxcGGO-rFbJxjTG1tBrBv0Msk5JakZUKs4uAcYcIqdWRrrEnf29y3HCEbF-SMeii4FtegMbPl8oEd61Zy6Rr17L0aF8ZUB7M0EKQ6QZ_5FqtsGyVhqiGsxM51BQ_1ELdf_vsbiYjc9QIap16XALLQsr6HA3LW8Oq4m5k43nZ1rGMsFhYNPV5xxouAr-x06iNxbN-pvObnDkWF_UkDf4agKV-JKcTvYz--El9953V3JKxx9KtQudTsKqRR4c02-XnCP5mCQ_4GG07Xyaxy18v76JfYbqLJ1bfzWYCvm0sXTks5ULLH0UtFETVzvT5jIiH2xRS0XjlRUPCcMWMPwRPVXquIVam6f2R_BzRiTJprLxAO3FxsU=w1784-h938-no
66j3LCKes9isk47rYOqnpeRuNhPn7JdQJ2YAQC9C
qSBMtgj5Ax53RuBaOZ8Uqlx5-IZQx3nI6FukNdBX
Just got to take a fibre glass mould from it next.
Next, preparation to move house with a wash and wax.
29KAenRAzZboR3KoncclxjiqXfDpMWQ0F0nEnpjh
xQNQdAg3OzrtrO78TeMZ3DNu5nL5zdJU9fOib8Ze
Even the carbon came up nice!
Friend brought the trailer up to move the car, but forgot the keys to the locks!  Had to cut them off early in the morning which must have upset the neighbours!
5loZaxTQPwEtfjCkbjTKXdoGfSeIp0TSxSB4Gkrl
Car is moved now to it's new home, slightly bigger garage with more light!
24UpG5u1WkWqUEI900h1ae4h2a1XPSnBIdcESEqe
Little bit nicer than what I had!
1 hour ago, dr_broon said:
Good stuff as always mate.
That HD wax looks like good stuff. Does it go on nice?
The garage at the new pad looks ace! Proper man cave! applause.gif1
Wax goes on very easily, I was expecting it to be tougher to apply to be honest.  It rained on the drive up and the water literally flew off!
Forgot that I also have my truck back which was fun to tow on my trailer - went well though   Luckily the Nissan was able to drop off the back with no issue until we could cut the locks off to load the Aerodeck
4AcqJNP5UwIoKaT0-HXhQDbKJ1NnbfJrOjFYk23I
Happy with the garage, loads more room and a door to the garden so I can get in and out without disturbing the neighbours is also a bonus!  Started to lay it out last night (tools are at the old house).  Excuse the rubbish on the shelf, cleaned out the truck at the same time as moving in!
Loads of room down the side and in front of the car!
MZa-tFf_esbk0ZLea7V2sFTyPGnu_-dJybV5SuyO
-_umYT3JPf-T6AFW9hN1hon2Z5qwSV-HMVPaWpTX
TJEF_jE-OJUbS01ZnpiYDOS9yFHW3JS-czEZTV9v
  • Like 3
On 12/13/2018 at 8:25 PM, dmrichards said:
How did everything go with the house move?
Garage looks a good size. When I eventually get a house a good garage and drive will be high on the list!
Will let you know Thursday, should be all done by then!
The one thing I've struggled to find is a house with a sensible garage, the older houses seem better.  Estate agents never seem to take measurements of garages so I've ended up taking a tape measure to each one or pacing it out!
Can't beat a good garage mate! I'd be lost without mine now. Said to Gayle, when we retire abroad (probably Spain) won't be looking at any house unless there's a double garage. She found a beauty the other night, 3 bed bungalow (new build) and the entire basement was a garage! Room for 3 cars easily and still space to work and have benches etc. Cheap as chips too £100.000! If we could have afforded to just now, we'd have been off! House was amazing. And the garage floor was all fancy polished (looked like a marble type material). Truly was amazing!
  • 6 months later...
  • 1 month later...
On 7/9/2019 at 8:01 PM, Vtisgilman said:
Any more news on this build? Not seen an update for ages.
Sorry yes lots of little jobs, need to post some updates. I’m on Instagram now as well which I try and update. Find me under delasoul_99
Okay, lets me see where I left off.  Moved into the new house and setup the garage
ue7QrnNETkq5Py3aOp5LlNv0AGN0X9BVmTl_prEf
Fitted door handles:
1PJwqqxrdlwFbte3fhcYDJAzEDJYUbOU9H5HPsBt
jHSLa0C7idP9UMSmfBJEqf2P-6d4RtrUwWl6DloQ
These could be better, need to build more support in the door, may not fit them.
Finally after all these years made the rear drop links.  Old vs new
ugcugO-6wrO7XeBkdo3eiPyGt5asEuJeHXEtMzeBfK2l0YUftTGZUFr-ZDTSj4qzqRBhavT4xL46tUoM
Refurbished the clutch slave cylinder and made the braided lines and brackets to hold it
npgI37zzX81GhoaGi2s3uKf4XYWTSa4ZBHu86UFd
azKlP92v6mz6ocdB3IzOgIdYtLZWOMQp1yP-uGdV
SFNoCOmJ_u44M6HagAwjgzY_gj3K4BboN-22cfTj
mCMb_0fOq1cR5L4CcgwmUO3rDYV9Fk4tdb_Aojse
W70dK3_e3goXdIMAgYuHuEBnxKNQOpXqG7B1TZsl
Q0nlX0Sqh9VEhK1vVPDi3ISah9nYa6IZ7qA6i45n
Fuel tank and battery tie downs
zGalKgQZ7vd1i7YQXdwO4bwZ0B8V5-LrXK_wtCoi
xcpwtR2FJQ0B1PMpWTiFLGSiMQCpb7LbR2P3CUJE
A5cVC-kw-eFZO7MFHnqeiIPvVnsAjbs3hmQChJ5d
RokMI0CjI1kTk9RsMvkas7ufI37z3bhirqtkI_cn
ECU and wireless steering wheel controls mounted under the dashboard
pQbTZbq7-D35yU2ZR7CMa7dRgynAMIFSTTAk7Rb1
K93AnVWcoRnu7WGjLS-PjZBgaIWaglbogpQewNMy
Fabricated a new centre console
ryT3vkJb9MWvvogdwoJjjGkW8sbhPE3WS86i1but
sP0V6ClXW67VzsexxiuMJCMm3cXhlqJvZUb2pjD4
XiYzUiimdUzPPGtrWvpsF-1XfsryQqxAsWgJINPW
S9v6yCxJgH-0DZ-8Nd1Ud82m9ooITQu-5pOEITKw
EzMM5ec9A5JJIpv-4A2lYgausR6N7k-lBbVoDrkb
MSA Tow straps front and rear
lWCiVYAvpkbujOmwzt026gXCEIulddnfX_PgrkPz
SI1UdxFSNHVPE1TfJXK7cXhfxD3cekwwJ513G_ar
wKBd-j-96VUjm4EqxLDknjCjcy9vfSlKQikUt1f9
jiK7UpAl2Y0KIq7ca5V1Qf9obwq9QU-mk21I85NQ
VUTRKK-RCJfLfjYjCerK6nmOYSLxD2XJFmRCyG9B
FsAF-_0GpEi5Hjix5X5eGev6HBUMXir4o-wkMoGr
xACQxQabagl7MqmdqQjV1_7fIUABwfqrxzh6RmUx
z5_a1Fyb9sNmHtkG763iN8kXwSyXg8KuyxEJp6uS
9h010ZbcFAC-yN0FqNXPwqi64QTf5mhLEi2n7ggo
Moved the Accusump to the rear footwell so it's lower down
HCx3GAzi3mvCHUmHACVFwvZMZSmb6E0ywNnmiVg0
oHG5Kv0MW-GhB9bm3tocUHSPMNupeTgrpPzbMT62
UUxP1PxqAVnNM1l_e0e4Trzj6BhOfZIxV8mMBACd
PwCm9VeVdD2Sr_lRFaxL-soExe8qYDtpOxGDcurA
LlQgJzdsd2XDDdO7aQp3xS2xXQ5Ip1k9dXW8JgGK
tEIVF7efYyzTa8rq56D3kUIV3B3iJ1tW6Ioyunce
Roll bars and Polyflex bushes
bClk3VwSXUbHlbW3FMceHl2A5cz6Eo3j14wi5SOj
Foot rest on the floor plate
VhX29zj1W4ZVm3trMxa9pT2F2bSv4UmkU4uE0wJQ
Yys9eOwNcc2LuWfbxgIXdZQr75hcQpSVDCbIusap
V7ZqzbijSof7WXPC8grI5eS78CIkrPquH3YRkSDB
Osj46wN_a6QXp_HGS5S2JJKzg1kBiWbXUNmf65JX
T9P_YjcHPTJgIggXBxEokPb_leQSREzD2PvPBWCM
Clutch fluid and clutch setup
P6ygv-K7gNR3i78vhmji9r5FqzKiMjeyp9mnBYyi
VszGt00r0wzETGYc36cd-pI1_r0IhMdAD-Ro14d2
Added a cable pull guide for the electrical kill switch, now means the pull cable is tucked away instead of in the passenger footwell
gp2c6Y6dsG0C44du8xqBX0LRSDK2J_77zFgvGvoR
Finally some work on the throttle bodies, added a much better bracket for the MAP collector block and connected hoses
4w2_WIQNLCSH5J2eiok2mkCvbO9h3lBY-4_EM1x6
Z8Q20QMXKJyRIAhIeHA29sKysIOBw-LritN7ztrT
aVl8hJVAOA-AgV9Qiv_nhTgX8JQ89EnVOgJkCCot
Aq3R25FXD9SkdQJuGlgKtnowETAdaT-UDouCdR-2
CKIMiacqntIPARFV9G_ksQgO4026BT2yzUh9XzdE
e7AC_IsQOvivwTpFHyEyde8SBZSV7fltSYuptYUH
Lots of small jobs but done over the last few months :)
