NOODELS MC2
noodels
You should get throttle wire and the throttle wire mounting bars from Integra type-r so throttle wire would sit nicely over the manifold. With Civic stuff you'll end up having throttle wire quite stupidly in the way of strut bar. I have that same problem and have all the other pieces for that conversion, except the wire pulley from some throttle body where wire is going to right directly, not upwards in angle like in civic/integra gs-r. But suitable pulley should be found in almost every 88 -> honda with 4point injenction except those B18C4/C1 engined ones. I just haven't had the time to find, I'll post pics when I found the pulley and can do the modifications.
I don't have Skunk2 but Blox manifold, but still, same problem.
8-) thanks for that infomation^^what ecu have you and did you notice much gains in upper powerband or loss in lower power according to the above dyno looks good gains all round tbh :)
regarding port matching any problems there :?:
