Silver slug 28/2/13 skip to pg 10!
VTISmichael
  • Replies 349
Top Posters In This Topic
Yea i know, seperates them from the rest by just adding a little novelty :)
I cant wait till japfest, its going to look so good and with all the other mb's daaaaaaaam!
gunna need to buy a second camera battery lol
just test fitted the rear, looking awesome but the wheels will come in a bit more once its lower but the inner arch deffo needs rolling, going to ring arch enemy at the end of the week and sort a date, enjoy :D
lol yeah i forgot that, what a day today, task was to remove the anti-roll bar droplinks, change the control arm and fit the coilover, well couldnt get the droplinks nuts off so i had to cut 1 off, the control arm bolts were a nightmare! the inner 1 was fine but the very outer 1 had been done soo tight i thought the nut had smelted to the plate but after burning it, chiseling it, hammaring it, cutting the head off and generally shouting alot i found out the entire bolt shoulder had welded into the bush but i managed to bend the plate alittle and angle it out, soo new control arm fitted, coilover and droplink fitted :)
noticed the coilover fork moves further outward about an inch which i think helps with camber and stiffens the back up, also the control arm has 3 holes to change the anti-roll bar droplink too, i dont if it actually makes a difference ?
just got to it all again tomorrow on the otherside now grr
did a test fit of the wheel after dropping it for the first time check the last pic...
rolling needed!! :D
