KiNK43 Posted January 13, 2013 Author Share Posted January 13, 2013 Oh dear... Hate welding, makes me a very sad boy Quote Link to comment Share on other sites More sharing options...
noodels Posted January 13, 2013 Share Posted January 13, 2013 long way from shock that could pop rivet a plate for now would take tank out if welding there though ,be if you dont Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 13, 2013 Author Share Posted January 13, 2013 it was solid and I broke through it, will defo weld it. Can see me wheel through the hole and its upsetting the whole looking good as new under there thing I'm going for. ill have it sorted by this time next week. Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted January 13, 2013 Share Posted January 13, 2013 Glad your doing it properly mate, you will only regret it later down the line. Quote Link to comment Share on other sites More sharing options...
james Posted January 13, 2013 Share Posted January 13, 2013 (rotten) what was the cause ? Quote Link to comment Share on other sites More sharing options...
noodels Posted January 13, 2013 Share Posted January 13, 2013 Really james The reddish-brown crust that often forms on iron and steel objects comes from changes that take place in the outer surface of the metal itself. This crust, called rust, is caused by the mixture of the metal with oxygen from water in the air.When moisture from the air, or from anywhere else, reaches an object with iron in it, oxygen in the water combines with atoms of iron to form molecules of a compound called iron oxide.The iron oxide particles remain suspended in the water, but when the water evaporates, the particles remain, forming a reddish coating on the surface of the iron. Without the presence of water, objects cannot rust. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 14, 2013 Author Share Posted January 14, 2013 ^^^^My guess is leaky boot seal Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted January 14, 2013 Share Posted January 14, 2013 ah that rust is a real shame, least you are dealing with it quickly and getting it out of the way! Quote Link to comment Share on other sites More sharing options...
james Posted January 14, 2013 Share Posted January 14, 2013 Really jamesREALLY My guess is leaky boot sealI dont know Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 14, 2013 Author Share Posted January 14, 2013 welder coming first thing Saturday. Just hope I can get the filler neck out without disturbing tank. Quote Link to comment Share on other sites More sharing options...
