Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 Those wheels look awesome Jake they just DC2 OEM jobbies sprayed up did you do them? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 2, 2014 Author Share Posted August 2, 2014 Yes and yes!I'm pretty chuffed with em 😊 Quote Link to comment Share on other sites More sharing options...
Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 Sorry for my ignorance mate just read back through, you got bottom end trouble big ends? Quote Link to comment Share on other sites More sharing options...
Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 I have a set of used bearings of that helps you but for the price of new ones might be worth getting a set its not too bad to do just time consuming and you gotta get the crank and oil pump off, I got one prepped in my workshop ready for a rebored and fresh pistons and rings in it. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 2, 2014 Author Share Posted August 2, 2014 Nah its spot on dude.. suspected I had an issue after my stupidity.. left oil cap off. But seems fine.. has since covered around 1200 miles. Has been tuned to 194bhp.Been to santa pod. Running well. Quote Link to comment Share on other sites More sharing options...
Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 nice sounds mint I will come see soon buy you a pint. 1 Quote Link to comment Share on other sites More sharing options...
Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 Can I ask does the intake make a big difference and did you use a 66mm or 70mm TB? I ordered the 66mm but thinking of emailing scott at htune for the 70mm Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 2, 2014 Author Share Posted August 2, 2014 Erm intake makes a difference with regard to how much power up top. I used a 70mm throttle body. Probably overkill for what I need but works well.But the power delivery is different really. Have to wind the motor up for best results!!! Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted August 2, 2014 Share Posted August 2, 2014 Yes yes yes! The EG sits perfect on those wheels Quote Link to comment Share on other sites More sharing options...
Guest jimbob738 Posted August 2, 2014 Share Posted August 2, 2014 Erm intake makes a difference with regard to how much power up top.I used a 70mm throttle body. Probably overkill for what I need but works well.But the power delivery is different really.Have to wind the motor up for best results!!!you mean turbo charger ? yeah that's next years steps Quote Link to comment Share on other sites More sharing options...
