NIKH25 Posted January 22, 2014 Share Posted January 22, 2014 As above, green key light should come on and then go out as the ecu recognises the correct coded key. 1 Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 Just tried it and the Green key light isn't coming on Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 22, 2014 Share Posted January 22, 2014 On 1/22/2014 at 6:16 PM, ammarbm said: Just tried it and the Green key light isn't coming on Not at all? Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 Ok just to show you guys What's happening. Here is the picture of 2 cables that were unplugged when he opened the coverThe Blue light that's installed in the carThe ignition switch where he resoldered the wires where they were connected originally Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 On 1/22/2014 at 6:22 PM, NIKH25 said: Not at all?No not when I turn the ignition on or off. . Not coming on at all Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 22, 2014 Share Posted January 22, 2014 Was it coming on before, what is the blue light for? How does it function? Quote Link to comment Share on other sites More sharing options...
ammarbm Posted January 22, 2014 Author Share Posted January 22, 2014 The Green light with key was coming on before and when I will switch the car off it will Flash and turn off like normal. Blue light has a red and black cable which were soldered to the old ignition switch. When I will turn the ignition on the light would turn off and as soon as I will turn it off the light will start flashing. Here is a pic of old switch where you can see the cables soldered onto it Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted January 22, 2014 Share Posted January 22, 2014 It sounds like an aftermarket immobiliser has been chopped in to the system somehow, the only thing I can suggest is to put it back as it was. 1 Quote Link to comment Share on other sites More sharing options...
simpo Posted January 22, 2014 Share Posted January 22, 2014 As above I reckon it was tapped into that ignition switch. Look at ur last pic looks like a red and black wire been chopped hunt around for some wires Quote Link to comment Share on other sites More sharing options...
simpo Posted January 22, 2014 Share Posted January 22, 2014 Also if he soldered the wires after maybe blew a fuse somewhere check all fuses and the ones under the bonnet 1 Quote Link to comment Share on other sites More sharing options...
