Right! Have decided to find out how to mod these front forks to get the front lower!
With a little bit of experimentational fabrication i think i've sussed it! Not sure if its the same way as already used but it'll do fine! Lol
Hmm, i did think about doing it that way tom but i thought that with the pinch bolt in the same place, the fork will have to sit at the same point on the bottom of the shock (where the pinch bolt recess is)????
What im doing is the collar that the brake lines bolt to, im moving that up 15mm, then the fork will slide on further (making a new, higher, recess for the pinch bolt to sit in) in theiry making the shock 15mm shorter!! :D lol
