Grant
know it might sound like a stupid question but you did put the sealing ring between the mani and decat didn't you I have seen it done before and they forgot to put it in rattled like hell but only at certain revs
Decat went on at the same time Nick. Wouldn't be surprised if it's knocking a little as there is no play in the spring bolts at all. Wife has taken it to the gym ATM so will look at it when she gets back.
Ah thanks for the heads up! But the design might help being that it's slightly baffled.
Phil, yes I did get the ring in there, it was a pita!
But either way, can't stay like it is, far too loud lol.
yeah I know what you mean I got 4-1 and decat mine is pretty loud but wouldn't say its too loud though. hope you find the prob hate rattles
Cheers mate. Have you got a 2.5" collector on yours? And is there movement on the spring bolts?
Yeah that could be it Nick.
Although, even when the rest of the exhaust isn't attached there's no play. So I'm thinking that the decat end that links to the mani isn't big enough in diameter.
Not sure whether to give in and put the standard mani back on, I have a couple of hours to play with it now so we'll see.
Tried the grabbing and shaking, no noise. Just Aiken it all apart though and noticed that the end that meets the mani was slightly bent. So bent it back and have out it back together. Also think that as the decat (adjustable when bought and came in 3 pieces so welded to fit) is probably 10mm too short which is obv pulling the rest of the system up.
Any way, put back together with adjusted flanges, will go out for a drive shortly. Dinner with the wife beckons now.
Which bracket so you mean simpo?
