Krzys Posted July 17, 2014 Share Posted July 17, 2014 Have a good sleep dude! Think the biggest problem with Honda's is the fluid boils quickly rather than the discs and pads giving up. That's what I keep reading anyway! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 17, 2014 Share Posted July 17, 2014 Is dot 5.1 ok to use?? Quote Link to comment Share on other sites More sharing options...
Grant Posted July 17, 2014 Share Posted July 17, 2014 Best sort mate .. I used this .... http://www.ebay.co.uk/itm/Motul-RBF600-100-Synthetic-Race-Racing-Rally-DOT-4-Brake-Fluid-500ml-/301221373000?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item4622316448#ht_1568wt_1071 And i tell you what thats a great price too Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 17, 2014 Share Posted July 17, 2014 Yeah 5.1 is okay as long as it's not the silicon based (purple) sort? There's two types of 5.1 from what I can see on Opie Oils. @UnicyclingTom has Motul 5.1 fluid. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 17, 2014 Share Posted July 17, 2014 Cool cool. Yeah I know it's good stuff. But just always used 4 cus that's what's recommended. So do you need to flush the system of dot 4 first? Or can ya just bleed the 4 out the system and keep topping up with 5.1? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 17, 2014 Share Posted July 17, 2014 Think you'd bleed it the normal way but keep topping up with 5.1, probably end up wasting some if the dot 4 fluid that comes out is clear as well as you probably not be able to tell what's what? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 17, 2014 Share Posted July 17, 2014 Ok cool. Thanks. I used blue stuff in the clutch which is helpful. So may e can find some blue 5.1 Quote Link to comment Share on other sites More sharing options...
Grant Posted July 17, 2014 Share Posted July 17, 2014 Hmmm i'd flush the whole system personally chaps .. Quote Link to comment Share on other sites More sharing options...
burbleboy Posted July 17, 2014 Author Share Posted July 17, 2014 I took @UnicyclingTom advice and used motul fluid. Mechanic in work gave me a syringe to drain fluid out of reservoir then advised to pump pedal 20 times per side whilst topping up with new fluid. 20 pumps of pedal seems a lot but that way guarantees a good flush!I don't have fade anymore but just disc problems as per this thread! 1 Quote Link to comment Share on other sites More sharing options...
burbleboy Posted July 17, 2014 Author Share Posted July 17, 2014 Quote Link to comment Share on other sites More sharing options...
