Mtec Discs...again :(
burbleboy
Have a good sleep dude!
Think the biggest problem with Honda's is the fluid boils quickly rather than the discs and pads giving up. That's what I keep reading anyway!
Cool cool. Yeah I know it's good stuff. But just always used 4 cus that's what's recommended.
So do you need to flush the system of dot 4 first?
Or can ya just bleed the 4 out the system and keep topping up with 5.1?
Think you'd bleed it the normal way but keep topping up with 5.1, probably end up wasting some if the dot 4 fluid that comes out is clear as well as you probably not be able to tell what's what?
I took @UnicyclingTom advice and used motul fluid. Mechanic in work gave me a syringe to drain fluid out of reservoir then advised to pump pedal 20 times per side whilst topping up with new fluid. 20 pumps of pedal seems a lot but that way guarantees a good flush!
I don't have fade anymore but just disc problems as per this thread!
