bought some new winter tyres for the accord wheels that I bought a time ago. These are 195-50-15 and much better clearance for the inner fender when you go low. No more rubbing now. The only thing is that the weights on the tyre are extreme close to the calipers :)
I think they look nicer than the oem mc2 wheels. Mounted other center caps too, with the red honda logo.
Went this weekend to the guy that maintains my car, for oil change, timing belt,waterpump, valves adjustment,etc.. and ended with the motor out :)
Found a coolant leak due the oil sandwichplate and sensor that were pushing on the waterhose that runs from the thermostat to the waterpump. So we deceided to get the motor out to look if there are other leaks and maybe do some other stuff like gaskets and so. Will change a lot now that the motor is out. Hopefully I get him back this week :)
  • Like 4
  • 4 weeks later...
now busy with some handling upgrades and powdercoating.
Hardrace bushings at the front and rear lca's,powdercoated in black and front compliance bushings . Also powercoated the 26mm swaybar in red. Also with new pu bushings and oem honda endlinks.
Planning for inner and outer tie rods from hardrace, and also the rta bushes will be swapped for new oem ones.
On 19-1-2017 at 8:28 AM, dr_broon said:
Good stuff on the powder coating... Will look tidy underneath. :)
Will there be any issues with fitting the bushes with the coating?
Don't think so, I'm not the one who will fitting them :)
On 20-1-2017 at 0:58 AM, Jayhoath83 said:
Nice chassis overhaul as well top stuff
Thx :)
