johngreen537 Posted March 5, 2011 Share Posted March 5, 2011 got another horrible one today read my EP3 thread, put vid in! Link to comment Share on other sites More sharing options...
jallen69 Posted April 14, 2011 Share Posted April 14, 2011 any luck on this mate?? Link to comment Share on other sites More sharing options...
blacksport01 Posted April 14, 2011 Author Share Posted April 14, 2011 Sort of yea. I've had timing issues and oil pressure issues with the replacement engine. Me and Ad fitted a new cam chain, cam chain tensioner, oil pump chain and tensioner, Reused my original oil pump, baffle plate and fitted a new oil pressure switch. Timing issues are now good but the oil light still comes on when engine is warm and only at idle. I was going to fit my original head to it but i dont think its worth it. We found a fair old bit of metal in the sump and minor damage to the block casing. So took another look at my original engine. Got it completly stripped down only thing left in it is the crankshaft. Anyway the crank doesn't look as bad as i originally thought and im pretty sure it can be reused The damaged cylinder bores look like they might hone out. I put a honing tool on order today so that should be with me next week hopefully. IF the bores hone out ok then i will be rebuilding the original engine with all new parts, the only original parts will be the block casing, crankshaft and cylinder head.Give me a about four months maybe less to get the money up together and i think it will be back up and running with no faults to worry about........i hope anyway Link to comment Share on other sites More sharing options...
jallen69 Posted April 15, 2011 Share Posted April 15, 2011 well keep up with it mate, i'd be fairly p*ssed off by now after fitting 2 engines already!!but by the sounds of things, you seem to of kept your cool good luck! Link to comment Share on other sites More sharing options...
jalesi2001 Posted April 15, 2011 Share Posted April 15, 2011 He has just had some really bad luck with the replacement engines he had got. But we will get there eventually. Its costing him an absolute fortune in McDonalds breakfasts for me!! Link to comment Share on other sites More sharing options...
knight Posted April 15, 2011 Share Posted April 15, 2011 Its costing him an absolute fortune in McDonalds breakfasts for me!! Link to comment Share on other sites More sharing options...
blacksport01 Posted April 15, 2011 Author Share Posted April 15, 2011 Yea i have kept my cool to a certain extent. I've had days where i just think about it all and just think i've had enough and can't be bothered with it anymore. Im praying this one cylinder bore hones out ok if it does im pretty certain i will have a perfectly good engine going back together. If it doesn't then i dont know what i will do. Link to comment Share on other sites More sharing options...
johngreen537 Posted April 15, 2011 Share Posted April 15, 2011 I'll take the facelift seats and door cards Link to comment Share on other sites More sharing options...
blacksport01 Posted April 15, 2011 Author Share Posted April 15, 2011 not quite at that stage yet john hopefullly will be roughly halfway to rebuilding the engine in a few weeks depending on if that cylinder hones out when i get my hands on the tool that is Link to comment Share on other sites More sharing options...
knight Posted April 16, 2011 Share Posted April 16, 2011 Good luck with the rebuild mate! i hope one day i will see it in the metal! Link to comment Share on other sites More sharing options...
