VTEC in 3rd
Dave
  • Replies 77
If you have checked the oil , and there is no lights on the dash , Whwn was the last time you changed the oil and what did you use , vtec is controlled by the vtec solenoid / ecu and oil pressure so if the solenoid works it can only really be oil pressure , I would start by taken the vtec solenoid off there is only 10 mm bolts holding it on and them clean out the filter inside and why its off give it a 12v feed and make sure its working , if that does not work i would change the oil and filter . Rich.
How do you get the vtec solenoid apart ? looks like a sealed unit to me ????
  • 2 weeks later...
