fyfie5 Posted December 23, 2013 Share Posted December 23, 2013 i snapped exactly the same piece when i first took my door card off! was so annoying, got a free replacement handle from the scrappy though. Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2013 Author Share Posted December 24, 2013 Bit of progress today. Center vent sorted! Link to comment Share on other sites More sharing options...
Mr Brown Posted December 24, 2013 Share Posted December 24, 2013 see she is a good car really. Bet your glad thats done now though, i hate things like that being broken staring at you all the time whilst you drive Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2013 Author Share Posted December 24, 2013 That's one of the annoying jobs done anyway! Just snapped the handle of the only screw driver that I could turn the ones by the handbrake though! Waiting for the drill to charge so I can use it to get them loose then I'll probably pack up for now as it'll be dark and don't want to leave the interior in bits.Had an idea about rescuing the regulator that falls to bits, will let you know if I get anywhere with it! 2 Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2013 Author Share Posted December 24, 2013 Just had a go with the drill, errmm....Got one screw out after breaking two heads! Link to comment Share on other sites More sharing options...
snakey135 Posted December 24, 2013 Share Posted December 24, 2013 b****r!!! We all get those days mate!!As said get some handles from the scrappy when you goto nicks... Or use a little cable tie!!Also i removed clocks to attack the trim from the drivers side first... There only metal spring clamps which hold the trim in... Mine are all gone now too!!! Still holds nicely!! Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2013 Author Share Posted December 24, 2013 On 12/24/2013 at 3:56 PM, snakey135 said: b****r!!! We all get those days mate!!As said get some handles from the scrappy when you goto nicks... Or use a little cable tie!!Also i removed clocks to attack the trim from the drivers side first... There only metal spring clamps which hold the trim in... Mine are all gone now too!!! Still holds nicely!!Yeah once I got the trim off I found that that was all that is holding it on anyway, the clips are all snapped and glued (badly), back on but at least that job is done! Got the drill on charge again to hopefully tackle the second screw by the handbrake but I worry about the screw heads I've already broke! Link to comment Share on other sites More sharing options...
Mr Brown Posted December 24, 2013 Share Posted December 24, 2013 i got all this to come mate. i need to have my centre column off to replace many bulbs and i want to redo the trim and fit an armrest in project MB3 Link to comment Share on other sites More sharing options...
NIKH25 Posted December 24, 2013 Share Posted December 24, 2013 Good to see some progress bud. On 12/24/2013 at 3:36 PM, Krzys said: Just had a go with the drill, errmm....Got one screw out after breaking two heads! Jeez though, that's not good. Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2013 Author Share Posted December 24, 2013 You'll have fun with that! Though I bet you have a better selection of tools than me, ideally I need a long screw driver with a chunky handle but I can't find the one we should have anywhere! Link to comment Share on other sites More sharing options...
