How often to change timing belt B18C4?
Dexter
Okay so it's been 5 years since my last timing belt change, but i've only done 40,000km / 25,000 miles since. The question is should i change it now? Haynes recommends every 5 years. The car sees some track days each year if that makes a difference.
x3, I did mine because it was 5 years since the last one even though it had only done around 30k miles and wasn't it bad condition.
If it does let go it will be messy.
Yeah, i guess better to be safe than sorry! So what else should i do on the same go, water pump i reckon, what about tensioner? Anything else? Last time i got it done at a shop as soon as i bought her, so i don't even remember what parts they replaced in the end, except that it was very thorough and cost €€€.
  • 4 weeks later...
It's the bearing in the water pump that usually let's go. And that's down to new belts being out on and tightening it up, then as the belt wears it slackens off. And then it obv starts again when you replace the belt. Think they're only about £50 so worth doing.
Tensioner is a must IMO.
  On 4/12/2014 at 8:55 AM, Aerodeckcivic said:
Need to do mine now that it skipped a tooth or two chasing an mr2 last night. :( are they easy to do??.
oh dear, have fun^^bent some valves then?
