Dexter Posted March 15, 2014 Share Posted March 15, 2014 Okay so it's been 5 years since my last timing belt change, but i've only done 40,000km / 25,000 miles since. The question is should i change it now? Haynes recommends every 5 years. The car sees some track days each year if that makes a difference. Quote Link to comment Share on other sites More sharing options...
Krzys Posted March 15, 2014 Share Posted March 15, 2014 I would do it because even though you haven't done the mileage rubber deteriorates, just for piece of mind more than anything Quote Link to comment Share on other sites More sharing options...
DAVEMB2 Posted March 15, 2014 Share Posted March 15, 2014 X2 5 years or around 60k - 65k witch ever you get to first Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted March 15, 2014 Share Posted March 15, 2014 x3, I did mine because it was 5 years since the last one even though it had only done around 30k miles and wasn't it bad condition. If it does let go it will be messy. Quote Link to comment Share on other sites More sharing options...
Dexter Posted March 16, 2014 Author Share Posted March 16, 2014 On 3/15/2014 at 8:36 PM, NIKH25 said: If it does let go it will be messy. Yeah, i guess better to be safe than sorry! So what else should i do on the same go, water pump i reckon, what about tensioner? Anything else? Last time i got it done at a shop as soon as i bought her, so i don't even remember what parts they replaced in the end, except that it was very thorough and cost €€€. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted March 16, 2014 Share Posted March 16, 2014 Water pump is non service item and shouldn't need to be replaced unless it fails. Lots of people still do it at the same time though. Quote Link to comment Share on other sites More sharing options...
Aerodeckcivic Posted April 12, 2014 Share Posted April 12, 2014 Need to do mine now that it skipped a tooth or two chasing an mr2 last night. are they easy to do??. Quote Link to comment Share on other sites More sharing options...
simpo Posted April 12, 2014 Share Posted April 12, 2014 I would do the lot. The last thing you want to do is put it all back together and water pump leaks a week later Quote Link to comment Share on other sites More sharing options...
Grant Posted April 12, 2014 Share Posted April 12, 2014 It's the bearing in the water pump that usually let's go. And that's down to new belts being out on and tightening it up, then as the belt wears it slackens off. And then it obv starts again when you replace the belt. Think they're only about £50 so worth doing. Tensioner is a must IMO. Quote Link to comment Share on other sites More sharing options...
3gdean Posted April 13, 2014 Share Posted April 13, 2014 On 4/12/2014 at 8:55 AM, Aerodeckcivic said: Need to do mine now that it skipped a tooth or two chasing an mr2 last night. are they easy to do??. oh dear, have fun^^bent some valves then? Quote Link to comment Share on other sites More sharing options...
