  1. Past hour
  2. Lovely car! Do you have a link to the wiper delete plug you used? Currently I have a random rubber bung I found in mine (just to stop things getting in when it's parked outside) but i'd prefer something a bit more secure like yours
  3. Last week
  4. Thanks for the update on the fogs - I managed to get a set of good condition blanking plates so i've removed the fairly rotten big fogs for now but I may reinstate them later. Left the connectors tied up behind. A bit more progress on the K-swap side of things: Drilled a couple of holes in the firewall just under the heater outlet to allow for the shifter cables to pass through (no photo, oops) Got hold of a billet shifter plate designed for an EG but it was sitting too proud of the tunnel so drilled out the fasteners for the shifter base plate and removed it DC5 shifter mocked up - was worried that it would be too close to the dashboard but it seems to just about be ok - the shifter box came with a short shifter already fitted which should help things Clutch and flywheel test fit - just waiting for various missing bolts to arrive from Japan before buttoning it all up. Toyed with the idea of getting an uprated clutch but we've gone with Exedy OEM EP3 clutch for now as it's many times cheaper than an uprated one (£126 vs ~£400) and I reckon it'll be OK for NA power levels. Any future plans to boost the car would require an LSD as well as a clutch upgrade anyway! Flywheel is a Competition Clutch 3.9kg
  5. Earlier
  6. dr_broon
    JDM JAM
    Some pics from the show
  7. Can confirm these are direct replacement to the existing big fogs. You might need to swap the plug over however. If I remember correctly the front seal wasn't great so I used a big o-ring between the glass and the front screw on cap piece to keep the water out
  8. We get properly ripped off for parts. It always amazes me looking at honda parts from America compared to here.. The dollar price is normally less than the price on pounds, and then you've got the exchange rate to factor in... It's mad. I got some gearbox bits for a fraction of the UK price even with delivery and tax. For the fog lights, a while ago someone fitted these which are supposed to be a good match for the rare big fog lights. https://ebay.us/m/3mKXkv I've had them in my watched items list since, but haven't got them myself as I fitted some big ones from a honda stream.
  9. Haven't had much time recently myself to work on the MB but my father in law has been cracking on with some jobs in my absence K24 mounted up to the engine stand to begin work K20 oil pump cut and fitted. There is a lot of dried up oil "varnish" within the engine so we may run some engine flush and change the oil again once it's running. RBC cam gear fitted (50 degree VTC) - Chains and guides refitted, timing checked. As the eagle eyed may be able to spot - unfortunately one of the oil pump guide bolts rounded off on removal... so after one trip to the local Honda dealer and £7.25 lighter i'm the proud owner of a new guide bolt! (It's crazy how overpriced these small parts are in the UK. They're £1.64 in Japan but of course that comes with a 2 week wait...) Front VTI-S lip test fit - needs painting of course. Currently pondering what to do with the fog lights as they are a bit of an eyesore - one of them has rusted inside and it looks like there's a surround missing. I might just get the blanks and delete them, weight saving (!).
  10. dan1
    '99 MB2
  11. Darius
    Car way too low
  12. You've been a busy boy, love the use of the sink while the boss is out. 😁 those bits are looking good.
  13. dan1
    '99 MB2
  14. dan1
    '99 MB2
  15. dan1
    '99 MB2
  16. Full size versions
  17. Popped up in my phone memories... 10yrs ago...
  18. Hi Ben, The calipers in the photo are for the 260mm front brakes, not the larger 280mm front brakes. Manufacturer caliper numbers for the larger calipers are LCA333 & RCA333. You can use eBay to get the oem numbers from them. Basically the calipers are the same for the mg zs180, mg zr160 & accord of that era, but the carriers differ i believe (ive not checked any fit on an mb other than a zs). I can confirm that the calipers and carriers from the zs180 will fit onto a mb2 4x100 as thats what I'm currently running! If youre upgrading the brakes you'll need to change the master cylinder and prop valve if you don't have abs for it to work properly. My setup is: Honda Civic MB6 brake master cylinder Honda Civic MB6 brake servo Honda 40/40 brake prop valve (46210-S5A-912) Wezmoto Braided front and rear brake lines (700mm front / 560mm rear) MG ZS 180 Front & Rear brake calipers MG ZS 180 Front & Rear brake discs Cheers, Dan
  19. Yes definitely! Focus at the moment is building up the engine ready to go into the car. I've got most of the things sorted that need/are easier to go into the car before the engine is in place, e.g. the shifter box, shifter cables and the power steering hoses (it's a real pain to reach the bottom of the PS rack with the engine in!) ready to go now I haven't got any engine mounts sorted yet but im hoping that some genuine Civic EG hasport ones come up for sale used at some point. They're incredibly expensive new (£750!) so I can see why people are tempted by chinese knock offs you can get on ebay, but personally I won't do that. You can get an alternative from Innovative Mounts for about £400 or so, but I dont need to order yet until i'm ready. A lot of these parts, its worth biding your time and seeing what comes up for sale on marketplace, ebay etc rather than getting things new as usually the price is high because it's come from the USA generally and import duties etc are rolled into the price. I've also managed to purchase a VTI-S front lip and side skirts from a car being broken, along with some door mouldings that were in better condition than ours which are all cracked and horrible (the ones right under the window on the top of the outside of the door). They seem to not be available new, i've tried both Honda and Rover part numbers. Most of the clips got smashed during the process of prising them out (I think you're supposed to do it from the reverse side with the door card out to release them) but it seems like you can still get those new fortunately. Also got a set of used MB-specific Meister-R coil overs which seem to be in very good condition so that was a score as they're also pretty pricey new. The rear lip is elusive but I think we may end up modifying the bumper somehow anyway depending on exhaust fitment etc so it's probably just as well for the time being.
  20. Good idea on the import 😎 must be getting exciting now you've got hold of it.
  21. Sure, we paid £700 for ours plus £80 delivery (which I didn't think was too unreasonable to be honest). I think that's about the going rate for one really. It's a JDM import engine from an automatic car - unknown mileage but it should have had an easier life than a UK one. Typically since I've now bought one there's a k24a3 from an accord showed up on eBay for £570! It doesn't look as clean as ours but would likely be just fine.
  22. Tubs2 looking good in the sun today, even with a thick coating of pollen.
  23. Good stuff mate. It's coming along nice. Do you mind if I ask what you paid for the engine? Just wondering about ballpark figures for the wife's type s.
  24. A rather inebriated looking K24A showed up this morning But it has the RBB markings on the head which is what matters - meaning it is the "full fat" version with 3-lobe VTEC and ~200hp. There is a similar looking version with 160hp and only 2 cam lobes so you have to be careful! Hopefully get that mounted up onto an engine stand at some point and take a closer look inside but so far so good. For peace of mind i'm going to give it a compression test and have a peek into the cylinders with a scope before going any further.
