- Last week
Some pics from the show
- 3 replies
- honda civic mb
- chat
(and 2 more)
Tagged with:
Ready for JDM Jam
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
Thanks both I forgot about that list (it's been really useful for me for other stuff actually) Added to the scary spreadsheet of parts to order... Over 50 items now. K-swappin' ain't easy.
