- Past hour
Thanks for the update on the fogs - I managed to get a set of good condition blanking plates so i've removed the fairly rotten big fogs for now but I may reinstate them later. Left the connectors tied up behind. A bit more progress on the K-swap side of things: Drilled a hole in the firewall just under the heater outlet to allow for the shifter cables to pass through (no photo, oops) Got hold of a billet shifter plate designed for an EG but it was sitting too proud of the tunnel so drilled out the fasteners for the shifter base plate and removed it DC5 shifter mocked up - was worried that it would be too close to the dashboard but it seems to just about be ok - the shifter box came with a short shifter already fitted which should help things Clutch and flywheel test fit - just waiting for various missing bolts to arrive from Japan before buttoning it all up. Toyed with the idea of getting an uprated clutch but we've gone with Exedy OEM EP3 clutch for now as it's many times cheaper than an uprated one (£126 vs ~£400) and I reckon it'll be OK for NA power levels. Any future plans to boost the car would require an LSD as well as a clutch upgrade anyway! - Earlier
Some pics from the show
- 3 replies
- honda civic mb
- chat
(and 2 more)
Tagged with:
Ready for JDM Jam
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
yeah it should be compatible.
