Does it smell burnt at all?
I'm sure if it was the chip, then they would maybe sort you out f.o.c or charge you cheapness seeing all the work has been done and all you need is new chip and saved map uploaded onto it.
I can't confirm this but that chip looks like the one already fitted when I bought the ecu. I can't search back ebay to get a picture as it's too long ago.
I would even question what chips Triple H use and see if they re-used the one that came with it.
I can't exactly mind from 2012 but it just looks the same as ebay selling pic.
Think that the sst chips are pretty much the main (if not only?) one that's used.
The chips themselves aren't that expensive...about a fiver. Obviously it's the Map that costs.
I'd they've still got the Map then they should be able to sort it out.
Chips are flashable so any tuner would use the existing chip and overwrite it.
Triple h should be able to a new chip from a saved file.
You can also revert the p28 back to its original rom see if the car idles then.
There's a location on the back of the board called J1 iirc. Two points will be soldered there. If you cut or remove that link. Will revert back to stock p28 rom
is it likely to be chip that's goosed then when I phoned triple h yesterday he said they don't keep the maps for p28 ecu saved to people car regs hmmmmmmm
He must be the only feckin tuner that doesn't keep the tunes then.
For £300 I expect my remap to be kept on file in case I want to swop back.
ano mate I'll phone again shortly and see what he says
