NIKH25 Posted April 20, 2013 Share Posted April 20, 2013 How much of a drop, right out of vtec. Mind, you're probably going quickly enough by then anyway. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted April 20, 2013 Author Share Posted April 20, 2013 out of iabs, but still in vtec..will double check on the m factory gear calculator... Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted April 20, 2013 Share Posted April 20, 2013 Not the end of the world then, as I said you'll be going plenty quick by then anyway, most opponents should have been dealt with. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted May 1, 2013 Author Share Posted May 1, 2013 gear ratios from the team m factory gear calculator... left are standard taken from the cars.homenetcs site, and right are what I've got. and the graphs showing the ratios... red lines are s9b and blue is mine. according to this, at 110, the change from 4th to 5th would be a drop from 8300rpm to around 5300rpm. Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 1, 2013 Share Posted May 1, 2013 That's not too bad then! Not much worse than 1st - 2nd on the standard setup! Could always get a VTEC controller if it can control the IABS? Quote Link to comment Share on other sites More sharing options...
knight Posted May 1, 2013 Share Posted May 1, 2013 That's not too bad then! Not much worse than 1st - 2nd on the standard setup! Could always get a VTEC controller if it can control the IABS? vtec controler only lets you move the vtec point not iab's Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 1, 2013 Share Posted May 1, 2013 5th looks good but 2nd 3rd and 4th look a little disappointing , also why are the shift points so low in that first chart. Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 2, 2013 Share Posted May 2, 2013 That's not too bad then! Not much worse than 1st - 2nd on the standard setup! Could always get a VTEC controller if it can control the IABS? vtec controler only lets you move the vtec point not iab's Good info! 1"£££$££"!! Maybe time for a new inlet then!? Quote Link to comment Share on other sites More sharing options...
dr_broon Posted May 2, 2013 Author Share Posted May 2, 2013 2nd - 4th have all effectively been shortened by the s80 final drive (improving acceleration), and the longer 5th is better for cruising.sure about the change points.. I wondered about that myself. I think that it's assumed that it's the best time to change gear for maximising power and torque, and improving acceleration Thing is though it doesn't know what engine it is, and obviously we'd take it up to the red line pretty much. reckon that iabs opening around 5-5.5k would be ideal to still get decent economy on day to day driving, but give you more uumph when you need it. Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 2, 2013 Share Posted May 2, 2013 Yeah that would be ideal, even if it was on the stock gearbox! Though the only way I can think of getting around it is either do what Kenny_tmt has done and machine the standard inlet or find a way to keep them open all the time? Quote Link to comment Share on other sites More sharing options...
