NOODELS MC2
noodels
Will just Na for now to see what it drives like and get bits and there is ots of bits and £s to boost a manifold for instance is 3-400 £s or get a log type,
Would rather do it once correctly tbh.with no shortcuts due to £s
found out turbo is T34 hybred though and ok for 360 ideal for my goals tbh.
I gotta say, i do prefer N/A, had a few turbo cars and when they ho wrong, they go wrong big time and its expensive! 360 bhp, wow, that's more than enough! I know, with a boosting setup up you really don't wanna skimp on anything. I got a quote from Ricky at racetech, he specialises in turboing Hondas, lots of experience in it. But yea for a good setup from him, fully fitted with a t5 turbo from an evo your looking at £2800. It's a lot of money!
  • 1 month later...
  • 2 months later...
Well sorted the JDM P72 <003AS>1992-95 now to see whats the hype about,>>better vtec power, though high humidity helps too atm,but its quicker,
fueling is better dont think it drops out of vtec so much !!also toooo slippy on v bumpy norfolks B roads..!! :shock:
will socket it and install the mugen chip with sk2 inlet manifold when i have time.. want to get some times 0-60-100 ect>kms :twisted: with pk9-p72+/-mugen chip...
>>>>my initial thought was on A road eeeeek!!!  its very aggresive >>this is much faster and They were right :smile:
http://cars.homenetcs.co.uk/honda-civic-mb6/modifications-ecu.htm
Soldering as per link cel light on after 5 mins goes of after ignition switched off ect.<normal until socketed>
dont know if the limiter is deleted though,as had an issue at 8.4k+ in 4th gear felt different? think it stops fuel rather than ignition cycle ? to be continued..goes better though 8-)
