- Today
Had a few pics from my father in law today who has been doing a few bits on the car Anti roll bar is on - there was a bit of confusion because whilst the brackets themselves are shaped symmetrically they fit on the car asymmetrically. If you put the brackets on the same on each side the ARB sits at a strange angle and the drop links don't line up (Once its completely fitted I'll probably make a post listing out all the parts you need as it's not particularly well documented online) After a bit of back and forth I did eventually find a photo from an unrelated MG forum thread that cleared up the matter. Here's how it looks now (notice how the passenger side is towards the rear of the car and the drivers side is toward the front. Maybe this is common knowledge but it was not obvious to me! Next job - fit hardrace lower control arms as the poverty spec MB lower arms are missing the drop link attachment point (plus the bushes are shot anyway) - Last week
Welcome mate 😎 Looks properly clean does that - low kms as well!. Almost looks brand new!
honda civic mb2 imagem_2025-10-11_202225893
costamb2 posted a gallery image in Showcase Members Car Gallery
costamb2 started following My 2000 MB2 Profile
Hello to all of you, First time posting on the forum, kinda wanted to share a bit about my mb2 since i first came to find some knowledge about these mb chassis. It's my first car, family owned since new and it's getting to the 100k km mark, and in my two years of driving and enjoying the car i can say it's a great car and frankly very underrated and deserves a lot more recognition The car has nothing major done to it, it's mostly stock aside from some small cosmetics. The mods are: Front mudflaps out of a junkyard pirate black mb2 1DIN android auto radio Reuphostered steering wheel Rear spoiler out of a Rover I have many plans for it later but most of em are cosmetics and i won't bother to modify a D14, maybe just a intake at best since the oem one is plastic. It's getting lowered and i want it to ride on some ek4 vti rims, or civic jordan rims and vti lip is also in the list Cheer, Costa.
Wheels suit it mate, 👍 -
Looking great mate!! I can highly recommend this 2k clear spray for the headlights instead of an end sealer. https://www.marlowpaintsupplies.co.uk/2k-2-in-1-headligh-clearcoat-a-s?srsltid=AfmBOoo1LxQxl8VEhYvsmuG0kFjmCflsOD0QmbvwUwqEnJsCPrUhCWGO I tried a holts restoration kit but the supplied sealer was rubbish, didnt last a year. Sanded it all down again, used that clear and its looking the same after 2yrs -
Looking good if I do say so myself! Headlights definitely letting the side down, need a good polish and coating. -
Nice progress there mate.. I bet it's driving nice with the new bushes and suspension bits. It's sitting nice. Interior bits and bobs sounds interesting
That arb was pretty crusty before ey? My old one was worse for wear as well, not quite that bad though. I guess they're pretty exposed to all the road grot -
It depends on the head unit. I know that some old Pioneer Head units are easy to hack. They have a 3.5mm jack input for audio controls and you only need a combination of resistance value for each button (vol up, down etc). Some others as JVC are more complicated as they need pulse modulation so you need to find or hack the code from remote control with reverse engineering. I dont know about new head units we have to do some search.. First of all you need to mount some switches on your wheel.and get or retrofit (if it's possible) the cable reel so that you can get 2 extra wires from it. That's what I am also searching for :)
- 14 replies
- 1
- electrical
- honda civic mb6
- (and 3 more)
Time flies doesnt it! So an update on the car since last time... Managed to get all the arms etc painted and polybushed. Thankfully id treated myself to a press last Christmas so that made life much easier! (plus who doesn't want a 20t press in the garage..). The supplied grease for the bushes is sticky AF and a right pain to remove when it inevitably goes everywhere though haha. So that's all been fitted, plus the coilovers & ARB's. Rolled the rear arch at the same time to try and sort any clearance issues with the ride height & wheels. Did plan on rolling the front wings at the same time buuuuut... far easier to yank it with my hands and do it that way. At the same time i fitted a new oil pan/gasket to sort an oil leak also. Got everything sorted, then on first drive there was a horrible squeak/squeal from the engine.. great, much sulking and swearing occurred! Happened regardless of clutch position and no chirping. Took the belts off to check and no difference. Initially thought might be a pressure build up internally (old oil pan gasket was leaking quite badly..). Changed the PCV valve (after much swearing and grazed knuckles), no change. On that test drive i realised it was now only happening when oil got above 80c and only when clutch pedal was pressed in, So, gearbox off, clutch + flywheel bearing changed and fingers crossed that is that sorted. Just need to finish bolting everything up and we'll see (if not im going to cry). Still need to sort the rust patches. A section is on the otherside of the sound deadening on the floor so that will need to be removed first, luckily i may be able to get some dry ice so that should help! While sorting that I've busied myself with stripping/ sorting the interior, basic run down is: - Chopped down the centre console so it doesn't go down to the floor and more El/EK-esque, Also removed the part which goes around the gearstick/handbrake. - Removed the cigarette lighter from centre console and moved down the heater controls, this gives me a place to fit some temp gauges under the radio. - Wrapped the interior loom with braided sleeve. - Swapped electric window motors to manual on the fronts (1 kg saving) - Removed window motors from the rear and now the glass is bolted in place. - Made some new seat brackets for the bucket seats to fit to the stock runners, all from 6mm ali so exceeds Motorsport UK guidelines (safety first!). Still to do - Fake suede wrap the pillar trims & centre console. - Make some door cards for front doors. - Wire in gauges/make centre console plate for this. - Remove that thick rubber mat on the firewall behind the pedals. - Still sort the rust! Cheers Dan. PS. Sorry for the ramble!
All looking good mate, those wheels should look great! The arb should defo help stiffen things up aswell. Doing stuff without a press is a right pita. I treated myself to one last christmas and it defo paid for itself when I did my polybushes haha -
Bought a set of (very) budget semi-slick tyres "Accelera 651 Sport Xtra" from a company called Tire Streets that i'd seen advertised on various youtube channels. I don't have particularly high expectations as they were extremely cheap (£280 for a set of 4) but according to various internet comments/reviews they seem to be reasonable. I can always upgrade them in the future if needs be. The rubber seems soft which is a good start for a track tyre. Normally I don't like to order tyres separately to fitting (as usually the fitting cost removes any savings) but I couldnt find anything suitable supplied and fitted so I paid the local tyre place £15 a tyre for fitting and balancing which seemed reasonable. Look forward to getting them on the car soon... Finally got around to finishing restoring an MG ZS 180 rear anti roll bar I picked up from a friend a few months back. It was in pretty sorry condition but it seems like they are not sold new any more. Fortunately, you can still buy drop links, poly bushes, and all the bolts so it was just a case of stripping it down, removing the rust, painting it and replacing as much of the hardware as possible. The bushes were a real pain to install without a press but after a lot of farting around in the vice I got there eventually... For reference here's how it looked before (!) - Earlier
Great, that means I am okay with the dash trims already. Hoping to find a badge and some mats in the meantime 🤞Just ping me if you want to get rid of that badge.
That's awesome! Would love to fit something similar to my aerodeck. I've fitted the 3 spoke DC2 integra wheel to it but would love the audio controls on the wheel. Is it difficult to add it?
- 14 replies
- electrical
- honda civic mb6
- (and 3 more)
That looks cool. Could do with that on my stepwagon as the radio is miles away!
- 14 replies
- 1
- electrical
- honda civic mb6
- (and 3 more)
I only want the CCswitch that match with the steering wheel if there is one and the cable reel with CC plug . All the other work is easy. Here is the audio controls that I have made in my last EK on s2000 ap1 steering wheel. All working for 10+years with no problem https://youtu.be/SSzox1OZ3PA?si=Zfc2L2NkCiWYsWUU
- 14 replies
- 1
- electrical
- honda civic mb6
- (and 3 more)
thanks dr, I'll try to find part numbers
- 14 replies
- electrical
- honda civic mb6
- (and 3 more)
Sounds like a good one then bud. Cheers mate. I'm on my second shell though unfortunately... Rust got the better of my first one. I got my resto done at classic and retro near Langley Park, but that was mostly chassis work. There's aldo a fella up near Throckley that I was wanting to get some work done on my wife's old accord, but he was dead busy at the time - GBR body repair. Looks like he does good work. If you're Newcastle way might be worth checking him out -
Dave replied to skylark's topic in Honda Civic MA/MB/MC
Welcome to the club mate! Your deck looks mint in the photos, nice to see another local one! You'll get all the info you need on these right here in the forum. 1st thing to do is check out our downloads section and get the official service manual for them. It's great for identifying parts etc and how they come appart. You'll be in good company here with your Civic as we all love these cars here, especially the Aerodecks. We also have a member called Paul who was a biker (bladerider929) so you'll see him on his bike in a lot of our civic5 meet/run videos. He's been off the forum for a bit but I'll let him know there's a fellow biker joined, sure he'll want a chat! Lol Start a wee project thread in the members cars section bud and get some more photos of the aerodeck up. Be nice to follow what you're doing with it. And big thanks to Karen (Mrs broon) for pointing you to the club. We also have a civic5 Facebook group for those who don't do forums, but the forum is where all the data on these cars is kept. We've still got the largest database on these cars there is, built up since 2009. Enjoy the club mate and hope to see your civic in the metal soon. -
Another thing to check is what type the buttons are. Some use voltage signals to operate lathing think that is probably for newer cars. Thinking you'll probably need the complete harness from the clock spring/spool to whereever it goes behind the dash. If you're just planning on fitting the ones for volume, then just terminating the other ones should in theory be fine as they won't be used. You'll also need the harness from the wheel to the radio as it will have some form of connector on it for the radio. Without seeing it, im guessing it will have a female 2.5mm or 3.5mm jack plug socket. Or possibly a male jack plug of the size mentioned above. Have a look in the integra forums (not the FB groups as the info in them is limited and sometimes incorrect!) for folk who are doing radio upgrades/double din conversions on their integra's. I think you'll be looking at getting these from America though as never seen any UK spec ones with those buttons fitted.
- 14 replies
- 2
- electrical
- honda civic mb6
- (and 3 more)
Anything up to 1998 model have the black marble effect dash inserts and the Chronos alloys, so those are the early models. Anything post 98 are the later vti/vtis models. 🙂
skylark replied to skylark's topic in Honda Civic MA/MB/MC
One lady owner from new , has every single mileage stamp from the same Honda dealerships from new 86k on clock, its pretty clean i did replace Headliner as it was sagging, just a little runs on rear arch's that i would love to sort out but not a clue who to go too this is my first car coming from motorcycles , yours looks so mint dude! -
So are you looking to replace the steering wheel with one that has cruise control switches? Assuming that the steering wheel fitment on the ma9 is the same as the MB/MC one, then you're looking at wheels with the same fitment as eg/dc2. I'm fairly sure that ek and accord shared the same wheel, but it's a different fitting to ours. EDIT... Just realised that it looks like the cruise control buttons are an add on to the steering wheel. It might be worth exploring parts diagrams like on Honda parts uk to see what optional extras might have been available and get some parts numbers to help your search. If, as the first post suggests, the US integra had it as an option, then the cable fell from that could be compatible - in which case have a spy at acura parts websites in the US for parts diagrams
- 14 replies
- 2
- electrical
- honda civic mb6
- (and 3 more)
Hi mate, that was my wife 😊 She messaged me to say that she'd seen an aerodeck there, glad that you joined 👍 Looks like a proper tidy example, been ages since I've seen another deck round here. Welcome to the club matey.
