- Yesterday
- Last week
- 2,196 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
Popped up in my phone memories... 10yrs ago... - Earlier
- 2,196 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
yeah it should be compatible.
- 2 replies
- general chat
- general
(and 1 more)
Tagged with:
Quick test pic
- 2,196 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
Welcome to the club and good luck with your project! Also used to (briefly) think about a K-swap a few years ago, but I quickly changed my mind after I found out that all the extra bits and pieces you need to make it all fit and work can easily cost twice as much as the K-series engine itself. And as far as I remember you're going to need EG parts for the engine bay, suspension bits and headers. While the M-chassis does share parts with the EJ/EK platform, Integra and EG parts are much more numerous.
