shaun Posted August 13, 2016 Share Posted August 13, 2016 when getting the steering wheel grab the airbag/horn ring with all wires and the 4 screws for ring pink wire and white wire are not needed. green wire is horn . red/yellow wire and red wire are for airbag before staring disconnect battery t30 star key to take airbag off unplug airbag and horn and earth wire make shore steering wheel straight 19 mm socket to undo center nut and take column cover off 3 philips screws then there 3 philp screws holding on airbag/horn ring on honda horn wire is red join to mg green wire airbag honda yellow wire to mg red wire and honda green wire to mg red/yellow wire do not solder with airbag plugged in as the heat can set it off put mg airbag ring on column screw 4 philips in. plug wire in. put column cover back on. put steering wheel on. plug airbag and horn in all in and working and srs airbag light is off but dont no if it will work in a crash and i'm not gonna crash it to test that part this is a guide so you will bee doing this at your own risk 4 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted August 14, 2016 Share Posted August 14, 2016 Oooo... Didn't realise that the mg wheel fitted. Nice one chief 1 Quote Link to comment Share on other sites More sharing options...
Finch Posted August 15, 2016 Share Posted August 15, 2016 I didn't think the airbag / horn plug would have been much different, probably could have kept Honda stalks and SRS wheel. One question though... Why? Now you have to look at an MG badge! Quote Link to comment Share on other sites More sharing options...
shaun Posted August 15, 2016 Author Share Posted August 15, 2016 the stalks are the same didn't change that just the AirBag Slip Ring / Squib honda mg my honda steering wheel badly worn and i had a spare mg and i saw a few people was asking about it so fort might as well give it a go. it slightly smaller feel nice to drive with and it soon have a red and carbon honda badge 1 Quote Link to comment Share on other sites More sharing options...
Finch Posted August 16, 2016 Share Posted August 16, 2016 12 hours ago, UnicyclingTom said: Lol 'Ring' Sometimes.. Just sometimes I worry about you. 2 Quote Link to comment Share on other sites More sharing options...
kalvtec Posted September 2, 2019 Share Posted September 2, 2019 I did this few months ago following the how to here... Well chuffed to say the least and was surprisingly easy considering im a novice... Excellent upgrade feels wicked overall and looks good too 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 3, 2019 Share Posted September 3, 2019 15 hours ago, kalvtec said: I did this few months ago following the how to here... Well chuffed to say the least and was surprisingly easy considering im a novice... Excellent upgrade feels wicked overall and looks good too Good stuff 1 Quote Link to comment Share on other sites More sharing options...
Skipday09 Posted January 6, 2020 Share Posted January 6, 2020 Hi what mg model is the steering wheel from? Thanks Quote Link to comment Share on other sites More sharing options...
kalvtec Posted January 15, 2020 Share Posted January 15, 2020 Hi Its the MG ZS 2001-2005 same shape/design as our civics 1 Quote Link to comment Share on other sites More sharing options...
Craigblight86 Posted April 15, 2021 Share Posted April 15, 2021 Used this to fit one to mine. Feels so much better 2 Quote Link to comment Share on other sites More sharing options...
