Sounds good! I'm willing to be the flywheel has helped quite a bit! Any idea if it's all been a straight swap in the end once you had the right bits or did the box need any machining work?
straight swap I think - he would have said if any had been needed :)
8-) glad it all came together in the end ;)
cheers 8-)
cheers 8-)
Sweet! I'm looking forward to the video! 8-)
Yeah I would! They normally say 1000miles to run in a gear box, I'd definately give her some time with the new parts! Bet you can already feel the acceleration is easier without booting it?
picked her up last night, had a few gentle miles last night and a calm drive to work this morning, and so far I'm pretty happy with the results - everything just seems a lot easier.
some numbers - revs are:
2.2k in 4th @ 30
3k in 5th @60
i think that to a certain extent the teg flywheel has offset the negative effect of the longer 5th - it now seems easier to accelerate from low revs.
bit of an issue with selecting 1st sometimes - the honda dude thinks it might just be the new 1st gear, but will keep an eye on it and is gonna give everything a check over tomorrow.
and 3.5k @ 70
