Krzys Posted September 4, 2012 Share Posted September 4, 2012 Sounds good! I'm willing to be the flywheel has helped quite a bit! Any idea if it's all been a straight swap in the end once you had the right bits or did the box need any machining work? Quote Link to comment Share on other sites More sharing options...
noodels Posted September 4, 2012 Share Posted September 4, 2012 glad it all came together in the end Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 4, 2012 Author Share Posted September 4, 2012 Sounds good! I'm willing to be the flywheel has helped quite a bit! Any idea if it's all been a straight swap in the end once you had the right bits or did the box need any machining work?straight swap I think - he would have said if any had been needed glad it all came together in the end cheers Quote Link to comment Share on other sites More sharing options...
Krzys Posted September 4, 2012 Share Posted September 4, 2012 Sounds good! I'm willing to be the flywheel has helped quite a bit! Any idea if it's all been a straight swap in the end once you had the right bits or did the box need any machining work?straight swap I think - he would have said if any had been needed glad it all came together in the end cheers Sweet! I'm looking forward to the video! Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 4, 2012 Author Share Posted September 4, 2012 gonna wait a week or so to get some miles on it before giving it some beans. Quote Link to comment Share on other sites More sharing options...
Krzys Posted September 4, 2012 Share Posted September 4, 2012 Yeah I would! They normally say 1000miles to run in a gear box, I'd definately give her some time with the new parts! Bet you can already feel the acceleration is easier without booting it? Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 4, 2012 Author Share Posted September 4, 2012 aye - you can. Don't feel the need to change down as much Will be interested to see how far 1st goes now - feels like it's pretty short. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 4, 2012 Author Share Posted September 4, 2012 picked her up last night, had a few gentle miles last night and a calm drive to work this morning, and so far I'm pretty happy with the results - everything just seems a lot easier.some numbers - revs are:2.2k in 4th @ 303k in 5th @60i think that to a certain extent the teg flywheel has offset the negative effect of the longer 5th - it now seems easier to accelerate from low revs.bit of an issue with selecting 1st sometimes - the honda dude thinks it might just be the new 1st gear, but will keep an eye on it and is gonna give everything a check over tomorrow.and 3.5k @ 70 Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted September 4, 2012 Share Posted September 4, 2012 Sounds like a result, why are you on here, you should be out running it in. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted September 4, 2012 Author Share Posted September 4, 2012 heh heh... don't tempt me Quote Link to comment Share on other sites More sharing options...
