MC2 Project - Chassis prep
DeLaSoul
After a long break away, redundancy and moving house a lot has happened to the chassis so time for the normal long update!
Throttle bodies - Now all fitted and the linkages are working
ukYnPu5PKTULa9NOD5L7gExiOCcz8-1WmIErP6nO
TK62Bpx0yHnpIASarx9UV8bm2kMyLZyUZ3rGJBRC
J3CYAFU7waJY6QT-H0nZfTVlbvoP_Z5eqNf6Uad6
Q5g4U1QTc44GYCY1pxSQLGHIEJCcUqOBAk8lpoRL
k8box_aNWWO60WkBQGFrfuT6tGe_yGuJt9K9Z6aR
Power Steering and oil cooler:
QsZYAJ4U_Qdu6eJ0jHeCRX1HeGWBxiTZnnVlwAAZ
G_bR4opU8Ti8gbHq-5thq91PmYzMCxizPbkylLDv
b20UW_NkoYlHfZGVviwOnsGYtfp0XzXQqjmdgjAp13qDp3Gp1TtWFLlev7cRivgD89pKOYpCXNj1wA9Q
PoBbUvfVvR6tYmPEyzI161cu4WzZc4afziTytQkW
BIMa_ml7bg9MYHI4pDz-Qw01abtxpDG6IUvixxWZ
kXKdpcKrXOz9MZK2FSjTdzA4sG6EZImzW7tppw_K
6IOaNFBpLC8CuWdkXFxjqoREONpJ3upUp2QGDdpE
G7VD2tm-fkLwlfITCDCFHBuzxIMsMJw7k3eEt6ZP
P4xOGwspa2_ozTUOIp3sgu8y-rgEXPq2iSI8VdAB
hX6obcgqP6RPx0cRn-Ik0S69vMKf-yTqtzdbP_pJ
Master Cylinders:
iUNO9bepHrFT1cp9w2pHQp9CaPnT6qQsVSXPDurA
bNVXIRt4a530ct7Tr73_XZ7q0xg8yFbDLS_cQlV7
zFDF0TCvIWvjAqlEv4I5lzSfrTU13aPLexKOe4ZO
ECU and Engine wiring:
dipqwbdVkmcy4ui_-7-UiCy_lWHPq7BRGINImVyv
4EW_mVmfNghb0ULTiFnzpcf2wqNh-kOmeAImAn2U
HeilfWz6k0kr3tIhCC9hcUYrvnQoieQlUcIJoUkE
Dashboard and Instrument binnacle re-mould:
vU1FoZSENGp8JSIxDMwIjDuSTVadXiG0S7xEBMk4
AAR0N6yKVakY9xRxN8b0zn7LuTyf5BEkP_BHBTtK
YvuPgJhvpsouShw1TAzW-6Y6Jjou-rMfBGwiad9J
2Gd_CGfYze1Kaa5p7BnroZPIWgAGYHj5V1xh4CYN
qw-z7V7Gu8PM3CkO0K5_MeutJBzEkoIIin4Lve3l
9ZqQYLXUHuEURwON-wtlw2sdl6ILpxxSOJm48AWA
XfToJTZmX78sYJsfGHJ2s8jkzEXQBGn2tyoj0ua6
keFxQZBm9xegkWFUJg67bdmZ4A1WnYnrgncxUWls
z3MGwSu8AOd4QQtoazOfZBzrufbY7q9s4C5pk-q0
6PdL64SIBb1pefMzpASJHY2I4zpEPX0aSqn4VoSe
59bm0cMrtwaViu1nqRcnmmUUEz3e7lCY68CwDtav
Bodywork and Aero:
lZobfSuNeO2AiZ-UKgojjFdyyRS4sFRJa6a_yY0Y
BTpcZ8yWbaxgoACjEg_8MEJrNb71UB4pAqnnvwsL
lV4M2rI1LFyTkIR4RTjXRFDgZOVuqSP8Re_p8QQb
Flat rear floor and extra bracing
Dez0mqLP9eVL7bY7_cxvU4xfQWuA2VRLjCajKKI-
SBUIbjPOfuCus6wljgXXu8qS9jnFpwUEnaG6MMh4
WTn4h2SQg3BoXeJgkv3YEljz5ux0HvRlMUiZV3FE
BYC side skirts
lspyWWFxrNgSWD4fnHa-gIcuii-7PDcY87kM_3fX
Big gay wing!
B7vFbZ2m1PTGCEXNRK8enSSC-S8ooX0yj3_G_S6y
ReLr0vMJ2-LYxqGDiat2UHv-u_f-8z6e4zULYHR0
QdKye18mxj_NBlXElqa1dqfG80qM9J6ROsw-Kq23
-0XApFT-30UjQRsIMRASvZ41-zaRrZS8CawV-pdS
Front splitter mounts
phVd13vXYTAywLBuPFnHh5mISMsNmpmooHRP6r_z
vZ-G-f_XZY7mYKYpYKXfm1u-VGDjSQ5ldfdMV8RG
Mounting to rotisserie:
EhrUjQR4parabtuccp_DqzQAsrutYsC2AP7JvUxN
qJQwYx6_wrAjs9LiQZirJBB-yX8B7DozZkHltap7
GB_Im7kRftsuuoeDdB3eLcnqYr_Hj9hIlZygu_LN
HxDo9Voh5PfChDDDWDWPWPV9QUquDdWAbhps3Vw9
HXaTaxBv7nU-lw7uL0r6y_VLPRwjc3LeFgmTFGZK
2zrkoi75Ujy9zaSeawQOxN0oHHGFP-qu3rQSb4yq
Chassis dolly so I can move it around in the new workshop:
ibZ8megxPnd53U-9JKNzINbyIhFt3V_-ESa-Xogg
Off to the bodyshop:
eHMGbcTQ7TmvxqnajxZRRA2t6AYn9uXGZ4O24DmT
Cam cover back from Spooner Restorations :) :
gWgvkR9z_F3ISwEvA4w9_nIn_0vJ8zzXnCv7a_bt
cf__6YJYZ3Lu6OD6aR50V-j-iT6K386fuBE8eTwL
u9KGCI5XAmo9Q0GDFVFHrRvPk18SwVShVptJo4PU
Parts for shot blasting and powder coating:
qRX5VmoSLeVyGyGiRXEsPEMV8SQF_M8E50Uo17_G
tyJD7dzlhcwKWOcS3FXlnTlxxYAZY2ZLc6HEiMz5
Body prep for paint:
2QdUOdjCs-RmpkMoaahHJFMa7OHu_uPzSegUhvXB
KsEDwDSHun0hcm6XAHNTF33LJeTM0uaEFrbz57cF
Seam sealer around a lot of the new fabrication work like the fuel cell well
QOseJf13OfRb3d92wZIjhGFHuvleK_T4k5qOWC9qsF_PwtKEymhsDR5msCa5-rNlUQnvzTfN0Cmzp5VE-KtxuLGTlcjsHfIF7saL9lXvunhpSe9hKhmwsdNaKB4sdIAPMh2OunDslh4hySa8GZTHEr1sXW36tDbf8G_xdEbwzP21lFSHz5PVo9GYZMJa82yEvWGozIjSKZkhTo49Kxsb2xDnuN0g_xDtbpiweC_PQOHjUT5iGkKVIzKKtyzNZwFMu7Mjbo-Jwz_tkUcyONwY1fmLh8EMctjFShhdspUeNt4YBKKh42aIwOAGaN-yaJpEeamk3HfwazIYbflbJ8fl_AU0sTwoe94Kk_FiMftNYDYxIK1WbZBoaVSSIVA7WxTbt5-DDiGhBbbrMm76GvBaxpn1Ncyse70dIxP_98sZmCbtahWaElhVTRDc7Hg0T7rPz2G15ZYYUwpfbkcNLbIPfnz0nwFqEpibN2-Gnpvu6axczePGPL22Yb8vnGdwrYId6FY2matAhSvhaMNlO3rGStPZSWDe-2YKAWkuWZZc1UR0d16BnDg2UV1JyiMo_qto7JiNsuIEoqMEHiaW1f8qUJo65uH320o1iRraMfEfO3AAyN8lu4pqXLh8XxoTg1QPnLxBtH4-hAtNL-sha_fKHZvhRY2htKraC-3Y=w713-h950-no
Underside black raptor
XngoxmgJekV7JfetHG60E7Uu5WKXyEObWcstDUy_
interior and engine bay are matt blue, chassis floor is blue tinted raptor
EiX9uwAhtE9sIoVqBFZ8xqkK_e1GHOglSzidClKH
Outside is gloss French racing blue, same as the cam cover
-dhmRj7QI37FJhThDX7vpSYi0Vy3pNKrCfiSBPkZ
A0wOlyt1kYQprBVlRjshrmsZ1nUXhvRoLGzOcifP
1nTWYKnROHuPbcUk1CjJR1Kz4KOcSOAQIDRZuwJh
Re-assembly begins now the paint is dry
ObRBs9pT0Lr1fkbjytPxT0zQxDARPTLTrBfpyytP
qLGHSSEsoV7mFDeFMV0wHgZ9EaeL8lNnpvqf7e6Y
TtVRKOvL7vrs6HGGx5GpfZmQxiO5n2mT3tdTMaws
Zqqtb4Wm2eBvThJccx7CA7tPDgCuDm3SsqohK3RX
ACjwnS3wy53Qis_41NphXWRB6ewYWUR_A7oyrezV
qp-LLGyb5Ij_MyErLAAFKFDRA22Itc7lkHzHjhNz
-a3CnglzZnruh7uZUVz-fpHb6aE70aLg5aygcBh7
Cut the bumper to clear the center front splitter mount
D2bsrm8Ueweo6vn03rmf_KpdKkhalVWf5XL1ytZE
r615gvdbn5sGhuVgK_cEpKy-9lJJCJuIk5ePXADu
Dashboard installed
mgeQLDeJ80H-bH8pmCPXTSrd-yp5kzgfe0TSo5I1
d46vTxHapEbM9kJLyxVq6rYV1Rrj1rUYzaGwcVxO
Center console in progress, second pull was much better but still not perfect, so I can use it to mock up the switches
x-WLO3xQ2mAp2yx94pEYdGs89jl1cYqfK8qqOfF4
5Evdva4z7Ws5-NBfVpJx_MK_srh-7DZ3e1FeAg2i
Front subframe, steering rack and ball joints all refreshed, new engine mounts all ready to be installed
f-M_GVs_mpLMpwyYfUJf2QGAZzS3_jJF1VPPq56s
Finally, engine progress:
Intake ports filled in and matched to intake manifold
uyYItRGSTFSj7aO09TGID7GT0wmb2w9af6jumrCp
13msd2B9SZd7e4UKKzO-Be90K5-E1tvGBcO_dKnj
bcYSmnDJ3MGu7IPl74WVnjWq681X8LysP6BKU11O
New valves installed and 3 stage valve job done.
sKQcEU6W0m4tJC7OmIbHggWu6vq2hXJiF4n2TYdo
fa3K-1Vl7G2xmZSbbMJoDJT8HBTyzive5In557Cf
A-bsb0MsJ6JbpUUIRmXxw4JMiznnkWOAqLsoHhAi
w8BnyKLUdwKRGGZDGhcDj8CWSYcOC_4KIX_HsHyn
Difference left to right
bM63mXPg3Un3coF1W-RyXqeOK8yazGtjL4ghMIfe
Block was cleaned, soda blasted and prepped (all bolts and brackets removed. Block guard fitted, bores machined true (+0.5mm) and honed
gmYFkU1hDXoSCwKTKIsePLq0bhQ4NYUkbrpPbCj7
_0w9EpudTUHN-90GrDhC7AKItwTfnAWtVnjodmcr
Crank balanced (I had a go but had to let the expert take over)
vGFwYutkmwRJQNdxabRw66vXqWy_kp4pSRKCFlh_
Wasn't too bad to begin with but we got it spot on
mL0_764C-tBKo19q2egrAqRrjqB0N4JVOlbjCWFj
Next was the flywheel
SI_Iuo_bBlMX6GwW99DaLS6jefIelil1JilXO65V
and clutch cover.  Had to dowel the cover as it wanted to move around a bit
LjjN7-QzSje7bz3oCz78ZAlryXiBNXKcro3L1XiX
rejcxrlcwkF_LpKzQBEY3Cr_NTURrBLojdmM3uUp
Jge2lL3x-7LI9qR3h9L0id6iizbMiqeFa_ctahWA
Carbon roof bung in progress
ei6Wmn_sKiN6QMoiNLjFvF4oVZ0H46bE8EzJfly5
And that's that!  Car rebuild is in progress and moving along steadily now it's all back from paint
Edited by DeLaSoul
6 minutes ago, Chandler said:
think i need to up my wiring game looking at that ha ha,
shame you've now moved so far away!!
cracking work as always, plus that BWR COP plate does the job good doesn't it ;)
I can always help with wiring mate, and after I saw your gold BWR plate I knew I had to have one!
ye man, well worth the money! need to get some proper plugs and sort all my wiring out from the component back to new plugs as its a mess in the cabin rlol.gif1
will give you a message to see where you got the plugs from etc and that can be my winter job
I probably still have a few new ones left from my job plus I have pins for the plugs that I bought a while back so I'm sure we can sort something mate :D
i'll give you a text now and we can have a chat man :D
12 hours ago, Blackwolf said:
Wow this build is amazing really inspires me to get on with mine would love some hits and tips if you ever have the time
Hi, no problem - if I can help with advice I'm always happy to.  I've learned a lot along the way and still learning as it's all going back together!
