MC2 Project - Chassis prep
DeLaSoul
Amazing how to guide mate! This is what Civic5 was always about, members creating guides like this when doing jobs on their cars. Love the photos and also the tips.
If its OK with you, I'll copy this and put it into a word doc format and add it to our how to guides? Mega useful guide and so well done!
PS: I'll be using this guide soon on DD's callipers! Just saved me a Bella lot of research and headaches!
Hi Dave,
Let me complete the guide first?  I have the correct seals and pistons now and hope to finish the job tonight/tomorrow so I can complete the write up
47 minutes ago, DeLaSoul said:
Hi Dave,
Let me complete the guide first?  I have the correct seals and pistons now and hope to finish the job tonight/tomorrow so I can then come up to Scotland and rebuild DD's.
Perfect mate :D
Rebuild time....
Okay, correct seal and piston kit this time!  Caliper paint all dry and looking good so on with the rebuild
General notes -
  • make sure everything is clean, really clean!
  • If it moves, slides or rotates, grease it
  • rubber seals are fragile, don't rush or use the sharp edge of the screwdriver to force anything in - it will go back together with patience
05wtcoKEtWvgCmq9d5AfeE2dQC-gZNIQCq0WOB-P
Step 1. Check the kit!  Per caliper there are 4 seals for the caliper, 2 dust boots for the carrier, some grease and a piston, as shown below
6SRo0o3bFEm5eDyigN8Av1HDs9w8Rpk6s87si6ov
Step 2. Handbrake lever seal - Before you mount the seal, check and grease the bearing.  You can see that there is a break in the needle rollers, this is for the handbrake pin.  Make sure you rotate the bearing so the hole into the caliper is open for the pin you'll fit later will drop through to the lever. THIS IS IMPORTANT!
nEhDNSFBYlbMftpjQ4-0BIrTsTTfLF4KZoOY3WSo
Step 3. Grease and fit the seal.  You must also grease the pin and groove for the handbrake pin.  Remember what was said before - note the orientation of the pin.  On the top there is a flat edge and a rounded edge.  Make sure the pin is all the way in and the seal sits in the groove in the pin
4hEjK9hJmCDeomqIIQHhRaxnOE9wUc3NTwyuFCHQ
3T727sk6SvGNFFVX2Ox5GYioPMjYHFs0zL4PNLtz
Step 4. Refit the arm, lock washer and nut.  Tighten nut.  The small arm should be one side of the spring pin, the longer arm the other side
2e-KSXfJ0ZRjRxyNxTrNm05vXLyTCn-C2p83aoyk
Step 5.  Refit the spring.  Note that the short arm of the spring goes against the pin first, then with the pliers you fit the hook end in to the arm
QTw-pBwF0wanAD2B_KFm9AH1wh8ui1GmFOVS843M
ANLqrZ670fn61T6f7Ig3s3vIzrnB0s_fa3WIKeEA
Step 6. Rebuild the internals - Now you have to swap out the seals on the internal mechanism.  There are only 2 seals, but it is important to note the direction they go in
STGIDr-QoRFQsaMsTUQOGKmH4OvVxui0fMoRIxXX
Small "Square" seal goes to the spindle - Note here that there is a groove in the seal, when taking the old one off note the direction and refit the new one the same way
"Round" seal goes to the inner mechanism
BbqpZHlQ-YxpQ-VqR1mzmgYK6ak6oOmrG2lAASGc
Remove the seal, grease and fit new one.  Also fill the hole in the back end with grease to hold the pin
AzUmpm7CUI9peVTYeExkyau0sBNleGXcpMnOmkDe
Swap out the square seal on the spindle
plLGuDvr22AHXboiCFExL-_hl3Ayfid9hmf5IsJF
Step 7. Reassemble the internal mechanism
vEVrurD9ClWTvyiOEzBEqaUd9R8pFKtbtCGURJcY
Step 8. Insert into caliper.  Okay, if you look into the barrel of the caliper you will see there are 2 drilled location holes, that match up to the pins on the mechanism above.
I couldn't get a good shot inside the barrel but you can see one of the holes in the shot below
SBhZ9yK3ceNv2ZtVG3aiqb_CSdmWFDuV1LFplY_Z
Lower the mechanism into the barrel.  The grease will hold the pin.  Turn the mechanism until the pins line up and it drops the last step into place.  Once it's in place you'll be able to see the cir clip groove at the bottom of the barrel :D
RR5VJGxfjJNk3Cl8hU0DK6n9U9sX-i1NO2UqOGxQ
Step 9. Insert the internal spring, bearing cir clip - be prepared to scream at the whole thing during this step....:wacko:
GxwA8Cg4WiTqo3pissiZIWh97bMbbQF8NQGwsSxb
Grease the thrust race and washer. Place the parts over the spindle in the following order - Bearing, Washer, Spring (narrow end first), top hat
xVfkQzLUxIv2WwBPIkjSwF9Qr4LuM4bnvgajOirR
Okay, lower in the cir clip.  I got it to the bottom of the barrel, then using 2 thin screw drivers I pushed it either side until the snapped into place.  I couldn't photograph this but if you've got step 8 right you won't need a lot of force to do this.
l4ucd95bOw0cIE4jfo2moh2MFHYi5ycYwnaA7KMt
8YXAqaR7wvIhNKdhCTD3C2kAkFqdUVPZ5JlYUZw6
Step 11. Fit the piston seal - grease it!
uP6Zrxfjb_lmnA5pqj1vh5tY1XB4sKCgVY8aCSyc
The caliper is now ready for the piston and dust seal ;)
Step 12.  Depending on what kit you've bought,  you either have a new piston with internals or without.  Mine was without so I had to swap over the spring and mechanism.  With circlip pliers, remove the internal cir clip and remove the parts
rry-BH4SHWqDm1s5qF6G1-ukU7z3LIVns2DFR5Pu
kPdeRzzHd6-y1TTRe7b4SdXgvxkthi8OWCeWmjak
OmH4hpPFXr1mp1hna8glpA_-yWcpQzJsmV9Fuwge
Step 13. Re-build the piston.  Replace the shaft, locating it in the bottom of the piston, then the spring and washer.  Lastly, replace the cir clip.  This spring is a hell of a lot more powerful so to get the cir clip into the grove, I used a 17mm socket and a vice.
jU0cDjs2qZVGhW5wEjAEAJJ1f4BecQjBcBq2kMDC
Place the socket inside the piston (as above) and compress everything in the vice slowly until you hear the cir clip click.  Then slowly unwind the vice.  To be safe I checked the cir clip was seated correctly and gave it a few taps with the socket and a hammer for good measure!
OSC4eSB3TnuCgJWaxyqlCXvT7oCtfeWjkSnVDX3S
Step 14.  Dust seal and piston.  This will either go right f!rst time or be thrown across the garage!  What worked in the end was as follows:
Grease the seal and piston, lots of grease!
Put the dust seal onto the piston, pushing the seal up the piston (not down over the top).  Push it all the way upto the groove in the piston so you have what's shown below
_BfhCISiEOYjSzLknbXq3zDpib6WNES4PDXPZh9h
Now pull the seal back down the piston
WU5i9nUgvA5XuQ2r8e04dT6gVA-F_Y7b-2z8FXX5
3hyusu6d_bMrEpkdlWkY-5iVTisGh2oWFAeVILJt
Until it's about to come off the piston.  Now the seal is essentially unraveled/inverted
r37yUqo9gcH0hGSxhebs7H4428mfX-M5bslfcPzR
Now, put the seal into the caliper, holding the piston.  The part of the seal that sits in the barrel is off the end of the piston while still on the piston.  This is important as if you try and fit the seal to the caliper first, the piston will not fit the seal.  Not easy to explain
CRi66FnzvtPhmPspmD4hKe9_sQwrBkPqD7UVwyGI
It takes a bit of time to get the seal into position.  I used a piece of blunt plastic to push the seal into place.  Once it is, you push and turn the piston back into place on the spindle with the large screwdriver.  If it's tight or won't go easily, chances are you've not seated the dust seal correctly
0ivKuxm_RvxscCzFr4eGE20dRdSVCY1C2U2nljWL
TC0MA6inYEwBzDr_0vNAhCwpc4GKXIrg1VaPL-RV
The seal will drop into the groove on the piston
apgW-Lp9-aA7Yf6ad0BXMinSENjNwk_h3P0LhaQE
Job done!  Repeat the above for the other side and you'll have 2 rebuilt calipers (or be stressed out that it wouldn't go back together properly!)
Check the handbrake lever works correctly (turn by hand), refit and bleed the brakes properly.  I'd also recommend spinning the wheel and making sure both the handbrake and foot brake works on each wheel before driving off.
36BWIhNikqksVKAlygo3ZGrdpsJOYLx66kDhH8W_
Edited by DeLaSoul
My old nemesis, spelling
  • Like 4
5 hours ago, Gel said:
More power to your excellent work Dave :)
Your guides are out and out porn to me.
Thanks
5 hours ago, dr_broon said:
Amazing write up... Better than a Haynes manual!
Cheers, its also a good reminder to me of what's gone into the build at times.  I didn't mind all the fibreglass work and making all the brackets etc. but this job was a real pain.
Haynes manuals, refitting is reverse of removal :lol:
  • Haha 1
Would have saved you a lot of time and effort if you'd used that :lol:
