5 hours ago, Krzys said:
Have you done the miles yet bitch?
yep, gotta do valve clearances now, which i'll do this week, then gotta raise the car for mapping after JDM Combe
So had it mapped yesterday and it made 210bhp so pretty happy with that. Need to change the Pistons and valve guides though and will be much better and less smokey. Here's some pictures from jdm Combe from the weekend. A couole taken by me.
  • Like 4
33 minutes ago, Chandler said:
cheers, need to change pistons to gain more power and sort the smoking out aswel haha
What pistons are you running? I thought you built the engine fresh :huh: or was it just headgasket / bolts and head?
running standard C4 pistons, i was told when i was getting it running i should've used B16B pistons to higher the compression.
and yes i did rebuild it but i didn't change the valve guides
