skymera Posted November 13, 2015 Author Share Posted November 13, 2015 Wow, these Pilot Sport 3's on the front feel SO good. I can't tell whether it's because the Pilot Exalto PE2's were low or the PS3 is a much better tyre, but damn. That cornering confidence. Though this is an issue (no no, not the filthiness of the wheel). Weights are hitting the caliper and making a ticking noise. Should I get them moved or wait for the tiny bit to wear down? Quote Link to comment Share on other sites More sharing options...
JK1245 Posted November 13, 2015 Share Posted November 13, 2015 Mate the ps3s are the best all-round tyres I've ever used. I hammered the s**t out of mine and still had a good amount of tread after 8-9months 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted November 15, 2015 Share Posted November 15, 2015 @Dave, do you know the answer to the other question?If I remember rightly, you need to wind it closer to the pedal by loosening off the locking nut, then turning the switch anti-clock wise. What you want is the plastic pin that sticks out the end of the switch to be pushed further back inside the switch. So turning the switch anti-clock wise should sort it. Then tighten the nut back up and jobs a good un! Probably best to unplug the connector on it before hand though as the wires will get twisted! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted November 16, 2015 Share Posted November 16, 2015 Haha another one for silica gel. My mate thinks I'm nuts. I've put silica gel inside each door. Inside the rear quarters and arches and inside the interior aswell. 1 Quote Link to comment Share on other sites More sharing options...
skymera Posted December 9, 2015 Author Share Posted December 9, 2015 If I remember rightly, you need to wind it closer to the pedal by loosening off the locking nut, then turning the switch anti-clock wise. What you want is the plastic pin that sticks out the end of the switch to be pushed further back inside the switch. So turning the switch anti-clock wise should sort it. Then tighten the nut back up and jobs a good un! Probably best to unplug the connector on it before hand though as the wires will get twisted!Thanks! Not had a chance to look yet but will make some time this Sunday.I've noticed it getting slightly worse (Or I"m more conscious of it). One thing that confused me, if I use my foot and lift the pedal slightly (normally to jog the brakes lights off) the lights can come back on. How can that work? Haha another one for silica gel. My mate thinks I'm nuts. I've put silica gel inside each door. Inside the rear quarters and arches and inside the interior aswell.Left my bag on the radiator to dry and it is now gone. Someone must have thought it was rubbish Also have the car booked in to the local window tinters. Long overdue, bit excited. 1 Quote Link to comment Share on other sites More sharing options...
skymera Posted December 10, 2015 Author Share Posted December 10, 2015 Not sure what I thought was happening with the switch but winding it towards the pedal like suggested has done the trick. Thanks! 3 Quote Link to comment Share on other sites More sharing options...
skymera Posted December 21, 2015 Author Share Posted December 21, 2015 At last, goldfish bowl gone! Very happy with the result 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 21, 2015 Share Posted December 21, 2015 Low! Like it! Quote Link to comment Share on other sites More sharing options...
skymera Posted December 21, 2015 Author Share Posted December 21, 2015 Had a couple oops moments when the car was being tinted.... Battery went flat in under an hour with just the ignition on to undo / do up the windows. It's never given me any grief but it could well be on its way out. With cold weather incoming (maybe?) I don't want to be stranded at home. Bosch S4 330CCA battery on Euros for £57 seems a good deal.All Halfrauds batteries are showing me 380CCAs... And secondly, after I removed one of the rear door cards, I never noticed the lock puller fell to one side. I shut the door and thought nothing of it.Wasn't until I went to open the door I noticed I'd shut the pully bit in the (locked) door.... Took some wizardry with the door lock to get it open.. Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 22, 2015 Share Posted December 22, 2015 Cold will drain the battery quicker if it's on its way out. Oops! Sounds like you had a good time with that one! Quote Link to comment Share on other sites More sharing options...
