haha yea, the horn itself is fine so was the fuse so was everything I could think of checking, all seemed fine but it just wouldnt work so I rewired one in least it works for now. switched out the rear swapped the rear caliper for one that works and now ive got a really soft break pedal, ive bled it a few times and then bled all four brakes and its still squishy so im just searching about at the moment to see whats causing it.
1 hour ago, Dexter said:
:-D i've had all of the same fails on my deck as well... apart from the missing wheel nut!
Im sure they were all there when i picked the car up, hundred mile drive back to the test centre must have shaken a couple loose haha :D
