WilkesyMB6 Posted April 22, 2015 Share Posted April 22, 2015 Wow! Love a good bit of engineering done properly too! Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted April 22, 2015 Share Posted April 22, 2015 Nicely done! Weird how they used a different subframe on our m's. Quote Link to comment Share on other sites More sharing options...
Krzys Posted April 22, 2015 Share Posted April 22, 2015 Good work! Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted April 23, 2015 Author Share Posted April 23, 2015 On 4/23/2015 at 6:32 AM, UnicyclingTom said: Top gorilla engineering! Notice the percussive maintenance tool in the bottom of the last picture? Quote Link to comment Share on other sites More sharing options...
Krzys Posted April 23, 2015 Share Posted April 23, 2015 On 4/23/2015 at 12:11 PM, DeLaSoul said: Notice the percussive maintenance tool in the bottom of the last picture? Standard issue in every toolbox isn't it? 1 Quote Link to comment Share on other sites More sharing options...
mc2vtimatt Posted April 25, 2015 Share Posted April 25, 2015 On 4/23/2015 at 5:30 PM, UnicyclingTom said: The gentle percussive toolDelicate persuasion tool....Essential to any good project! Quote Link to comment Share on other sites More sharing options...
Chandler Posted April 30, 2015 Share Posted April 30, 2015 just read through it all mate and you've done some cracking work fair play!! and that wiring!! i thought i was doing ok when i tucked most of mine and done the S2K clocks but that is insane!!!! 1 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted May 2, 2015 Author Share Posted May 2, 2015 On 4/30/2015 at 12:16 AM, Chandler said: just read through it all mate and you've done some cracking work fair play!! and that wiring!! i thought i was doing ok when i tucked most of mine and done the S2K clocks but that is insane!!!!Cheers mate, wiring is one job I like doing to be fair. Still working through the rest and learning as I go. Quick update now I'm near a PC..... So I've checked the roof bung actually fits in the hole with a tight gap for sealant by using the spare roof I have Now time to sand and fill as smooth as possible ready to take the mould from. Filler primer and sanded the sides and covered the flange area with tooling resin to make a smooth surface for the vacuum bagging tape to fix to later. The dash has now gone from this.... To this.... Filler, sand and wood primer to seal everything ready for tooling resin and sanding, lots and lots of sanding!! Wasn't sure how to get the centre console to match up the dash, needed to fill that area in somehow Made up a cover that aligns with the inside of the centre console and glued, filled and sanded. Cover area and areas where I broke through the resin again with more resin. More sanding, filling and recover in primer Another sanding session and it's ready to make the split mould. Clamp the tool to a base and build supports for the parting flange. Used a plastic pipe to simulate where the roll cage. Time to enjoy the bank holiday weekend and chill out Quote Link to comment Share on other sites More sharing options...
noodels Posted May 2, 2015 Share Posted May 2, 2015 Been busy,looks very professional & need to Pm youno i wont your inbox is full ??regarding a squib Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted May 2, 2015 Author Share Posted May 2, 2015 On 5/2/2015 at 6:54 PM, noodels said: Been busy,looks very professional & need to Pm youno i wont your inbox is full ??i need a squib Sorry, emptied out a few old messages so you should be able to PM me now Quote Link to comment Share on other sites More sharing options...
