Looking good mate!
Regarding height, I did the same as Alex, set them up equally, however unless your on a perfectly flat surface, and I mean absolutely perfect, the ride height isn't equal. Only by 4-5mm. But I'm anal like that and can see it.
The woes of coilovers lol. But she handles spot on so wouldn't want to sacrifice normal ride height for handling.
Looking good mate!
Yep, my older brother had my front left 5mm lower than the other three corners and was the main culprit for my rubbing too! Tape measure for the win! Check and check again and when you're 100% sure, check again!
Thats it Alex, mine is on the drivers side too... Same thing with coilies when first fitted... Set them up next to each other equally then when fitted the N/S/F arch was 21.5" from floor and O/S/F arch was 22" from the floor... Same on rears lol but nvm!! Was you able to get me a link btw for decent extended hex wheel nuts? Cant remember what pitch thread they are, 1.25 or 1.5??
Don't measure it to the floor as that's a variable point, I measured from the top of the arch to the centre cap with the car in the air! :)
what colour you after mate? will be 1.5 mate :)
best thing to do is get to a garage where they got a flat ramp for when they do tracking etc and then measure there :)
Got a 4 poster at work, probs would have been best to measure on that but never mind, i know theres roughly half an inch in it between sides but not too fussed at the moment lol... Blue is what im after mate ideally, and need to have the hex attachment as the rim holes are proper tight lol!!
