NIKH25 Posted December 10, 2013 Share Posted December 10, 2013 That brother of yours needs to sort his priorities out, hasn't he ever watched eastenders fambly always comes first. Link to comment Share on other sites More sharing options...
Krzys Posted December 10, 2013 Author Share Posted December 10, 2013 Phil Mitchell would be most disappointed Link to comment Share on other sites More sharing options...
snakey135 Posted December 11, 2013 Share Posted December 11, 2013 Shame about the air con pulley but least gives you the opportunity to chuck the air con out if you want! Link to comment Share on other sites More sharing options...
Krzys Posted December 12, 2013 Author Share Posted December 12, 2013 On 12/11/2013 at 12:46 PM, snakey135 said: Shame about the air con pulley but least gives you the opportunity to chuck the air con out if you want! I like having it handy too much Soooo managed to get her on a ramp last night, didn't go anything other than just check over the car and it's good news! There's stuff to be done but overall she's decent, I'm so pleased! Found that the main pulley on the aircon pump is quite loose so will need a new aircon pump at some point, I'm not ditching the aircon! Front drop links could do with replacing, they're original by the look of it too! Rear drop links are knocking but I have the MG ARB to go on which will cure that! Baffle has collapsed in the back box, got another standard back box at home to see me through! Front tyres need replacing, rears have more tread but to be fair, they are a cheap brand so may as well bin those too! Then for the interior which I worked out myself I need: Drivers door window regulator - Found an eBay seller doing brand new units for about £30! Drivers seat reclining knob - Mine just spins Clock bulb has gone. One or two dash bulbs have gone. Dimmer switch iffy. Headlining is sagging at the back. Discovered yesterday afternoon after work that I may have a leak, but could also be because of the drivers window regulator being a bit naff! Want to try and do a smoke test to see if there's any other leaks to be found and check sunroof drains! Rear parcel shelf is in bad condition. Rubber tray at in the centre console is missing. Finally the heavy clutch and the thermostat need replacing. Seems a fair list but to be honest most of it is minor and cheap enough to sort! Link to comment Share on other sites More sharing options...
NIKH25 Posted December 12, 2013 Share Posted December 12, 2013 Doesn't sound too bad, as you say mostly just niggly little bits apart from the clutch. Link to comment Share on other sites More sharing options...
Krzys Posted December 12, 2013 Author Share Posted December 12, 2013 On 12/12/2013 at 9:09 AM, NIKH25 said: Doesn't sound too bad, as you say mostly just niggly little bits apart from the clutch. Yeah I'm pleased with it! I've got a while until MOT for the front links and I'll probably get some tyres in January when funds allow a bit more! Need to pay off a chunk of credit card but I'm also going order a bunch of the cheaper bits when I get paid so I have something to go at while I'm off over Christmas! 1 Link to comment Share on other sites More sharing options...
Krzys Posted December 12, 2013 Author Share Posted December 12, 2013 On 12/12/2013 at 10:04 AM, UnicyclingTom said: oil, filters etc?Oil is still quite clean and at a good level. Doesn't seem like she's done a lot of miles since the last service, reciept says it was done a couple of months ago! Link to comment Share on other sites More sharing options...
feck_on_a_stick Posted December 12, 2013 Share Posted December 12, 2013 That's some list but as you say all nice little things that can be done over time. No ticking time bombs.......touch wood Link to comment Share on other sites More sharing options...
powerofdreams Posted December 12, 2013 Share Posted December 12, 2013 Bet that's a weight of ur shoulders. Link to comment Share on other sites More sharing options...
phill1975 Posted December 12, 2013 Share Posted December 12, 2013 at least its all small things you can sort and get her back to her glory Link to comment Share on other sites More sharing options...
