- Past hour
Ready for JDM Jam
- 2,197 replies
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- Last week
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
Popped up in my phone memories... 10yrs ago... - Earlier
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
yeah it should be compatible.
- 2 replies
- general chat
- general
(and 1 more)
Tagged with:
Quick test pic
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
Thank you for the warm welcome both I am basically following guides for an EG K-swap as the car seems to be almost identical as far as a K swap is concerned. Even the EG conversion harness (to connect the new engine loom to the existing car loom) appears to work for the MB. Spent a day on the car today and progress as follows: Bye bye D14! Some areas of surface rust in the engine bay that we'll go over with a flap wheel and spraypaint over just to stop it getting any worse but not found anything that needs any welding etc so that's good news Made a bit of a mess knocking out the leftmost engine mount bracket (required to install the EGK2 Hasport mounts). Drilled all the spot welds out but it still wasn't budging so ended up going in behind it with a hammer and chisel and it eventually came off - the chassis has suffered a few battle scars but nothing a bit of sanding and paint can't cure! I've agreed to buy an EP3 civic gearbox so now that the gearbox has been chosen the next job I think will be to get hold of a shifter from an Integra DC5 and get that mounted in the car and get the shifter cables fed through to the engine bay and the shifter mounted. If i'd gone for an FN2 or accord gearbox I would've needed an accord shifter as the pattern is reversed. And finally my first mod! A set of clear indicators, I believe they were from an accord - I had to file off a small tab on the casing to get them to fit the connector was a direct swap so that's a good result
