- Past hour
- Today
Ready for JDM Jam
- 2,197 replies
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- Last week
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions - Earlier
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
yeah it should be compatible.
- 2 replies
- general chat
- general
(and 1 more)
Tagged with:
Quick test pic
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
Good work bud. Make sure you have a check under the plastic scuttle panel where the wipers are. That's a notorious spot for collecting old leaves and grot, and can be hidden rust back there. The clear repeaters really lift the look of the car I think.
