Dave Posted December 5, 2017 Share Posted December 5, 2017 Amazing how to guide mate! This is what Civic5 was always about, members creating guides like this when doing jobs on their cars. Love the photos and also the tips. If its OK with you, I'll copy this and put it into a word doc format and add it to our how to guides? Mega useful guide and so well done! PS: I'll be using this guide soon on DD's callipers! Just saved me a Bella lot of research and headaches! 1 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 5, 2017 Author Share Posted December 5, 2017 On 12/5/2017 at 5:18 PM, Dave said: Amazing how to guide mate! This is what Civic5 was always about, members creating guides like this when doing jobs on their cars. Love the photos and also the tips. If its OK with you, I'll copy this and put it into a word doc format and add it to our how to guides? Mega useful guide and so well done! PS: I'll be using this guide soon on DD's callipers! Just saved me a Bella lot of research and headaches! Expand Hi Dave, Let me complete the guide first? I have the correct seals and pistons now and hope to finish the job tonight/tomorrow so I can complete the write up 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted December 5, 2017 Share Posted December 5, 2017 On 12/5/2017 at 6:02 PM, DeLaSoul said: Hi Dave, Let me complete the guide first? I have the correct seals and pistons now and hope to finish the job tonight/tomorrow so I can then come up to Scotland and rebuild DD's. Expand Perfect mate 2 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 5, 2017 Author Share Posted December 5, 2017 On 12/5/2017 at 6:51 PM, Dave said: Perfect mate Expand I see what you did there lol 2 Quote Link to comment Share on other sites More sharing options...
Dave Posted December 5, 2017 Share Posted December 5, 2017 Lmao almost got away with it! Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 5, 2017 Author Share Posted December 5, 2017 (edited) Rebuild time.... Okay, correct seal and piston kit this time! Caliper paint all dry and looking good so on with the rebuild General notes - make sure everything is clean, really clean! If it moves, slides or rotates, grease it rubber seals are fragile, don't rush or use the sharp edge of the screwdriver to force anything in - it will go back together with patience Step 1. Check the kit! Per caliper there are 4 seals for the caliper, 2 dust boots for the carrier, some grease and a piston, as shown below Step 2. Handbrake lever seal - Before you mount the seal, check and grease the bearing. You can see that there is a break in the needle rollers, this is for the handbrake pin. Make sure you rotate the bearing so the hole into the caliper is open for the pin you'll fit later will drop through to the lever. THIS IS IMPORTANT! Step 3. Grease and fit the seal. You must also grease the pin and groove for the handbrake pin. Remember what was said before - note the orientation of the pin. On the top there is a flat edge and a rounded edge. Make sure the pin is all the way in and the seal sits in the groove in the pin Step 4. Refit the arm, lock washer and nut. Tighten nut. The small arm should be one side of the spring pin, the longer arm the other side Step 5. Refit the spring. Note that the short arm of the spring goes against the pin first, then with the pliers you fit the hook end in to the arm Step 6. Rebuild the internals - Now you have to swap out the seals on the internal mechanism. There are only 2 seals, but it is important to note the direction they go in Small "Square" seal goes to the spindle - Note here that there is a groove in the seal, when taking the old one off note the direction and refit the new one the same way "Round" seal goes to the inner mechanism Remove the seal, grease and fit new one. Also fill the hole in the back end with grease to hold the pin Swap out the square seal on the spindle Step 7. Reassemble the internal mechanism Step 8. Insert into caliper. Okay, if you look into the barrel of the caliper you will see there are 2 drilled location holes, that match up to the pins on the mechanism above. I couldn't get a good shot inside the barrel but you can see one of the holes in the shot below Lower the mechanism into the barrel. The grease will hold the pin. Turn the mechanism until the pins line up and it drops the last step into place. Once it's in place you'll be able to see the cir clip groove at the bottom of the barrel Step 9. Insert the internal spring, bearing cir clip - be prepared to scream at the whole thing during this step.... Grease the thrust race and washer. Place the parts over the spindle in the following order - Bearing, Washer, Spring (narrow end first), top hat Okay, lower in the cir clip. I got it to the bottom of the barrel, then using 2 thin screw drivers I pushed it either side until the snapped into place. I couldn't photograph this but if you've got step 8 right you won't need a lot of force to do this. Step 11. Fit the piston seal - grease it! The caliper is now ready for the piston and dust seal Step 12. Depending on what kit you've bought, you either have a new piston with internals or without. Mine was without so I had to swap over the spring and mechanism. With circlip pliers, remove the internal cir clip and remove the parts Step 13. Re-build the piston. Replace the shaft, locating it in the bottom of the piston, then the spring and washer. Lastly, replace the cir clip. This spring is a hell of a lot more powerful so to get the cir clip into the grove, I used a 17mm socket and a vice. Place the socket inside the piston (as above) and compress everything in the vice slowly until you hear the cir clip click. Then slowly unwind the vice. To be safe I checked the cir clip was seated correctly and gave it a few taps with the socket and a hammer for good measure! Step 14. Dust seal and piston. This will either go right f!rst time or be thrown across the garage! What worked in the end was as follows: Grease the seal and piston, lots of grease! Put the dust seal onto the piston, pushing the seal up the piston (not down over the top). Push it all the way upto the groove in the piston so you have what's shown below Now pull the seal back down the piston Until it's about to come off the piston. Now the seal is essentially unraveled/inverted Now, put the seal into the caliper, holding the piston. The part of the seal that sits in the barrel is off the end of the piston while still on the piston. This is important as if you try and fit the seal to the caliper first, the piston will not fit the seal. Not easy to explain It takes a bit of time to get the seal into position. I used a piece of blunt plastic to push the seal into place. Once it is, you push and turn the piston back into place on the spindle with the large screwdriver. If it's tight or won't go easily, chances are you've not seated the dust seal correctly The seal will drop into the groove on the piston Job done! Repeat the above for the other side and you'll have 2 rebuilt calipers (or be stressed out that it wouldn't go back together properly!) Check the handbrake lever works correctly (turn by hand), refit and bleed the brakes properly. I'd also recommend spinning the wheel and making sure both the handbrake and foot brake works on each wheel before driving off. Edited December 5, 2017 by DeLaSoul My old nemesis, spelling 4 Quote Link to comment Share on other sites More sharing options...
Gel Posted December 6, 2017 Share Posted December 6, 2017 More power to your excellent work Dave Your guides are out and out porn to me. Thanks 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 6, 2017 Share Posted December 6, 2017 Amazing write up... Better than a Haynes manual! 1 Quote Link to comment Share on other sites More sharing options...
DeLaSoul Posted December 6, 2017 Author Share Posted December 6, 2017 On 12/6/2017 at 7:35 AM, Gel said: More power to your excellent work Dave Your guides are out and out porn to me. Thanks Expand On 12/6/2017 at 7:39 AM, dr_broon said: Amazing write up... Better than a Haynes manual! Expand Cheers, its also a good reminder to me of what's gone into the build at times. I didn't mind all the fibreglass work and making all the brackets etc. but this job was a real pain. Haynes manuals, refitting is reverse of removal 2 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 6, 2017 Share Posted December 6, 2017 On 12/6/2017 at 1:08 PM, DeLaSoul said: Cheers, its also a good reminder to me of what's gone into the build at times. I didn't mind all the fibreglass work and making all the brackets etc. but this job was a real pain. Haynes manuals, refitting is reverse of removal Expand Would have saved you a lot of time and effort if you'd used that 1 Quote Link to comment Share on other sites More sharing options...
