kinks EG project. B18 turbo
KiNK43
Today's the day. Hopefully cracked on. Got all me s**t ready to go loadsa stuff.
big a*s pile of stuff to go on. Clutch and flywheel. New yuasa 5057 battery. 5 mtf. 4 cans of plastidip.
All sorts of toolage and some scruffs.
Haha still a fair bit to do.
So today I have fitted new clutch and the repaired gearbox.
Sorted out the blowey exhaust. Used expensive gaskets and spring fixings. worth every penny pull In nice and tight.
Cleaned and fitted replacement iacv. Starts and idles now after a bit of tweaking.
refitted the coilovers and put new droplinks on.
refitted battery tray with new yuasa 5057 battery.
also fitted new front hubcentic spacers. Fronts sit nice now.
rear to be fitted later.
Fitted the filled torque mounts.
touch wood gearbox is good. Rusty brakes were very noisy on test drive but couldnt seem to hear anything to worrying in the gearbox. Real test will be high Rpm shifting though so not out the water yet.
clutch is lovely. It's a joy to drive this car With a normal clutch. It's really light and smooth. Very nice.
so needs a damn good clean up in the engine and externally.
I need to strip the brakes down and clean and grease. I suspect the handbrake cable has stretched on one side so may have to replace that. The front discs are looking a bit ropey. We're perfect when sold dunno what guy did to the car really. Like beach drifting or summit.
need to fix windows. And then go to the body shop.
But really not too far off.. very weird driving this then jumping straight in the deck. Both civics both c4s but sooooooo different.
