Jayhoath83 Posted October 17, 2014 Share Posted October 17, 2014 Ooooooo twinkley i want Quote Link to comment Share on other sites More sharing options...
Chandler Posted October 17, 2014 Share Posted October 17, 2014 maybe, but bronze will be nice 1 Quote Link to comment Share on other sites More sharing options...
phill1975 Posted October 18, 2014 Share Posted October 18, 2014 I would say bronze with either silver flip or maybe black Quote Link to comment Share on other sites More sharing options...
ammarbm Posted October 28, 2014 Share Posted October 28, 2014 I like those lugs mate.. The ones I got off eBay are not good as the color is coming off.. How much were yours? Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 3, 2014 Author Share Posted November 3, 2014 Will deffo be bronze when time and money allows, also when ive dealt with more important things...Like my car rediculusly overheating last week and spewing water everywhere out the expansion bottle... Fan wasnt working so assumed that was the problem... After changing the rad fan switch it still didnt work, then i noticed the bottom hose was staying stone cold... So took out the termistat, which looked a bit worse for wear, chopped the gunbins out now seems to be running fine!! Alot of chalky white s**te came out the pipes though...Now clutch pedal has hit the deck... The list gets bigger!!! Quote Link to comment Share on other sites More sharing options...
3gdean Posted November 3, 2014 Share Posted November 3, 2014 wounded, least its on the slave cylinder and not the actual clutch Quote Link to comment Share on other sites More sharing options...
noodels Posted November 3, 2014 Share Posted November 3, 2014 You replaced the stat now then as winter prevent window misting problems,may want to flush the system as it would get in the heater matrix and replace with a coolant additive.hope head gasket is okmaybe remove slave and clean bore with 1000 fine paper and re-bleed worked on mine 4 yrs ago Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 3, 2014 Author Share Posted November 3, 2014 Will be replacing the stat this week, at the moment it's just on the stat seal with the middle removed to get the flow back. When I replace it I'll flush the system through and antifreeze it, as right now its just running on water to get me to n from work!Im going to bleed the clutch today and see what happens... Then take it from there... May try that slave trick if i need to mate cheers! Quote Link to comment Share on other sites More sharing options...
snakey135 Posted November 3, 2014 Author Share Posted November 3, 2014 Soft water being what, destilled or boiled? ... So thats probably the reason for the thermostat siezing... Will soft water break down all the s**te? Quote Link to comment Share on other sites More sharing options...
Chandler Posted November 3, 2014 Share Posted November 3, 2014 soft water doesn't have all that crap in ha ha now you've unsiezed it it should be ok now Quote Link to comment Share on other sites More sharing options...
