Grant Posted December 23, 2013 Share Posted December 23, 2013 Shit when you have days like that bud. Everyone has them. Keep your chin up though, you'll get there eventually!! Link to comment Share on other sites More sharing options...
KiNK43 Posted December 23, 2013 Share Posted December 23, 2013 Poor Nick If it's part of the handle that's not too bad then, could even silicone it I guess as long as it stops the rod popping up and off?Little zippy tie mate 1 Link to comment Share on other sites More sharing options...
Krzys Posted December 23, 2013 Author Share Posted December 23, 2013 Little zippy tie mateYeah that could work too! Cheers! Weather looks like it should be okay tomorrow so may have a look then! Link to comment Share on other sites More sharing options...
DAVEMB2 Posted December 23, 2013 Share Posted December 23, 2013 Arrr bad time on working on her I still have them working on trinityD had the dam front end off three times with lights and its back to how it started off ,for now lol I would give you a hand if you was near ( not like that everyone you Pervs ) as for the trim pull it out you can always find another ,and if anything it be the metal clips that have snapped off find them and bit of fire glass solves that that's whats on trinityD stronger than before . Link to comment Share on other sites More sharing options...
KiNK43 Posted December 23, 2013 Share Posted December 23, 2013 I didn't bother with those clips. They all snapped off. Just put it back without was fine. She'll get there anyway. Did you get the package I sent?? Link to comment Share on other sites More sharing options...
KiNK43 Posted December 23, 2013 Share Posted December 23, 2013 HAHA you said rod.I've managed rod and shaft in two separate posts today Link to comment Share on other sites More sharing options...
simpo Posted December 23, 2013 Share Posted December 23, 2013 Ha ha sounds like one if my days on the car! Well least u got vents in one less job Link to comment Share on other sites More sharing options...
hickster Posted December 23, 2013 Share Posted December 23, 2013 Those door handle clips break all the time you can usually get em to stay with a small zip tie for a bit. Getting the door cards off is a bit of a mission the first few times until you get the technique. Next time your in the scrapyard grab a few of them as spares (along with a handful of trim clips and those caps that go on the grab handles ). Theres a good breakers near Crawley if your heading down to Nicks. For the dash trim remove the instrument cluster surround and work in from that end. If you need to lever against the dash use something really wide like a 3" scraper. 1 Link to comment Share on other sites More sharing options...
Krzys Posted December 23, 2013 Author Share Posted December 23, 2013 Those door handle clips break all the time you can usually get em to stay with a small zip tie for a bit. Getting the door cards off is a bit of a mission the first few times until you get the technique. Next time your in the scrapyard grab a few of them as spares (along with a handful of trim clips and those caps that go on the grab handles ). Theres a good breakers near Crawley if your heading down to Nicks.For the dash trim remove the instrument cluster surround and work in from that end. If you need to lever against the dash use something really wide like a 3" scraper.Thanks for the tip! Will use an ice scraper to try and leaver it off! I didn't bother with those clips. They all snapped off. Just put it back without was fine. She'll get there anyway. Did you get the package I sent??Not had it yet dude, might be slow given the time of year though. Link to comment Share on other sites More sharing options...
vtec2011 Posted December 23, 2013 Share Posted December 23, 2013 Oh dear... glad I'm not the only one who had the exact same problems! I snapped the original dash trim to fit the carbon look-a-like dash trim, so that didn't really matter anyway... Door handle clips broke when I tempted to replace both front window motors (even they was nearly impossible to replace) There are some very frustrating bits and bobs on these MB's but I'm use to it due to working on bloody Renault's every day Better luck next time (if you haven't mulled the car already...) Link to comment Share on other sites More sharing options...
