My PB MB9 Aerodeck! Engine rebuild in progress
vtec2011
Cheers @powerofdreams :)
Right, you horrible lot :lol: Pics are finally here! Or.. some of them anyway. I'm still making some adjustments and the front end is way too low but it looks so cool!! Suprisingly it doesn't rub, scrape or anything. The only thing did scrape were the front mudflaps which are now removed.
The coilovers were a bit of a bast**d to fit to be honest. I had to slightly pull the bottom front forks apart to make them fit the front coilovers and the bolts were seized on the car. I had to replace 4 bolts in the end. When the coilovers are fitted, I used a vernier gauge to make sure both sides of the coilovers are equal. Will be using this for further adjustments! :)
  • Like 5
What are we going to do when they go independent!
Pay them?
Lows look great Kyfer!! 8-)
I would say 10mm higher on the front would look spot on, but if it's not scraping then that's also a big win! :)
Lows look decent pal!!
Mine rubbed the inner arch like no ones business when it was that low! Lol
same here raised mine and handled better also,wonder how long before it will spit the inner arch out !!
also camber would be long way out with no adjustments made.
looks nice though :twisted:
