- Last week
Meant to update this! Got the ABS fault sorted, was right rear abs sensor. Was supposed to be a 10 min job to remove/fit, only one 10mm bolt! Said bolt was rounded to he'll, so took time to get that out. Then the sensor itself wouldn't come out! In the end had to remove brake caliper, caliper carrier and brake disk so I could hammer the sensor out! What a faff. New one fitted, all back together and abs light now gone!π Also had her in for her MOT which she failed. Didn't fail on much tbh, handbrake efficiency, broken o/s/f coil spring. Couple of advisories for o/s/f ARB drop link and a tyre slightly perishing. Got everything done except the tyre as I'm gonna replace all 4 soon anyways so she now has a clean bill of health. Still driving nice, and love her to bits!
Me being lazy! Lol Don't think she'll need anything tbh, maybe the usual handbrake adjusted but other than that hoping she passes when I get her booked in. In the middle of moving house again so will get her seen to after that. Got a mate who has a recovery vehicle and his rates are decent so he'll be moving her to her new garage in Octoberπ
- 920 replies
- honda civic mc1
- honda civic aerodeck
- (and 7 more)
- Earlier
- 5 replies
- electrical
- honda civic mb6
- (and 3 more)
Thanks for that - totally missed your reply - thats great info Since this post I found the mistake and bought a set of MGZS 180 front 282mm calipers and carriers second hand for Β£80 delivered which wasn't bad at all really. The seals etc looked ok but they were a bit grotty so we soaked them in evaporust and then my father in law stripped them down and painted them in high temp silver and they look a lot better now. Still not got any pads or discs yet but that will come in time... A running engine first would be a good start π (see my build thread for the fun i've been having there...) I definitely plan to change to rear discs at some point but as it's quite a lot of work/parts required so I'm going to see how I get on with rear drums to start with until budget allows (currently diverted for more important topics) - whilst it doesn't look or sound very good it's not as bad as you might expect... -
Cheers mate, loving it to be honest.. It's dead comfy for munching miles, if not quick. Totally the opposite to the deck.. Sat up tall, soft air springs, and lazy drive, instead of low down, stiff and engaging. Got the best of both worlds now π
Forgot to update this.. Got through it's mot with a few bits needed, but just maintenance tips things, drop links, ball joints etc, and some advisories on thin pads. Got sorted, and got some nice new rainsports on the wheels off Karen's old blue accord, and got them fitted this week. Quite like the look of them. Also refurbed the compressor for the air suspension, and fitted a new pressure switch, so that's all working great as well now. Glad to have ditched the "snow leopard" winter tyres that were on the steelies, and with some more air in the suspension, it handles much better. Did the pads while I was on, and pleased I did, because they were OLD. the driver fronts were the worst... They fell to bits when I took them out. Also, chucked a bit of paint on the side skirts where the garage had peeled their stickers off and took the paint with it before they sold it. Fixed a hole in the corner of the spoiler with some filler and got some paint on.. Rough as a badger's arse, but it works for now. Fitted the spoiler for the first time today, and love the crazy look it has. Finally, made a little shelf to go over the air tank to allow camping stuffing to take place. Adventure ready! π
Exciting times mate (worthy of some of school civic5 smilies) -
Big moment this morning after a few days of battling with electrical problems we finally got the car started! It sounds terrible as theres no exhaust, various vacuum leaks and things not plugged in, but feels great to get to this point, absolutely buzzing that we can start to tidy everything up now and get it driving To be continued... -
Another good day of progress today Radiator in Hybrid Racing power steering kit in and connected up Fuel lines connected Radiator hoses and heater hoses connected Started to wire in the engine harness - lots of mess and unnecessary wires to tidy up but I'm going to wait to hear the engine run first before I go mad chopping out something that we might need! I reckon another solid day on it next weekend and we might be able to hear it run... -
Thanks so much for the reply dave, ive had it sat for a bit and finally got round to a more thourough diagnosis, I suspect it's the water pump that's crapped itself as there is a nasty rattle from the belt assembly when starting the car and when letting off the throttle. I'm thinking that this may have been causing it to stall out as well as it only ever happened to me when warm and I know that bad water pump can cause your engine to stall out and struggle to hold idle at low speeds when letting off the throttle and coming to a stop. Bit of a pain as well as water pumps seem to typically be sold in a kit with timing belt and tensioners and would mean doing these as well while it's all off. I dont have any experience with doing timing belts and as much as the aerodeck manual will help with most of the headache, any advice would be really appreciated. Definitely no headgasket failure, but the coolant looks like it could do with a good flush and tbh the radiator could do with being replaced sooner rather than later as its pretty tired. Really appreciate the reply, hope ya keeping well π
ondreyy replied to ondreyy's question in SOS! Help!!
Oh, thank you so much. So it is the bolt joint pressed-in and the whole arm will need to be replaced for easier repair? -
Big milestone achieved there bud. Looks weird the engine being so the way across to the driver side with space at the other end.. So used to it being the other way. Exciting times π -
After nearly a month delay with far too many emails back and forth we finally got hold of the replacement engine mount bracket from Innovative Mounts and the engine is now finally bolted in! Got a few other bits fitted after this photo like the radiator, hoses, and fan, and then started to work on some of the plumbing like the clutch line. Getting exciting now - to be continued!
