- Today
Haven't had much time recently myself to work on the MB but my father in law has been cracking on with some jobs in my absence K24 mounted up to the engine stand to begin work K20 oil pump cut and fitted. There is a lot of dried up oil "varnish" within the engine so we may run some engine flush and change the oil again once it's running. RBC cam gear fitted (50 degree VTC) - Chains and guides refitted, timing checked. As the eagle eyed may be able to spot - unfortunately one of the oil pump guide bolts rounded off on removal... so after one trip to the local Honda dealer and £7.25 lighter i'm the proud owner of a new guide bolt! (It's crazy how overpriced these small parts are in the UK. They're £1.64 in Japan but of course that comes with a 2 week wait...) Front VTI-S lip test fit - needs painting of course. Currently pondering what to do with the fog lights as they are a bit of an eyesore - one of them has rusted inside and it looks like there's a surround missing. I might just get the blanks and delete them, weight saving (!). - Yesterday
- Last week
Ready for JDM Jam
- 2,197 replies
- honda engine b18
- honda civic mc
- (and 4 more)
Looks ace buddy
- Earlier
- 2,197 replies
- 1
- honda engine b18
- honda civic mc
- (and 4 more)
Full size versions -
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
yeah it should be compatible.
- 2 replies
- general chat
- general
(and 1 more)
Tagged with:
Quick test pic
- 2,197 replies
- 2
- honda engine b18
- honda civic mc
- (and 4 more)
