dr_broon Posted December 2, 2014 Author Share Posted December 2, 2014 On 12/2/2014 at 8:50 PM, h4mza said: Like how you installed the EP3 seats, seems like the easiest way, what size steel plate did you buy?Cheers bud... You know, i really can't remember, but it was a good few mill thick. I'll see if I can check without needing to do yoga in the morning. Quote Link to comment Share on other sites More sharing options...
h4mza Posted December 2, 2014 Share Posted December 2, 2014 On 12/2/2014 at 8:55 PM, dr_broon said: Cheers bud... You know, i really can't remember, but it was a good few mill thick. I'll see if I can check without needing to do yoga in the morning. No problem mate, I'm trying to fit these seats myself without too much work. Instead of cutting and using MB rails, I'm using steel angle brackets from B&Q which I can bend to MB rail shape. I then need to do what you did, weld the MB rail or in my case the angle bracket onto a steel plate and weld the steel plate onto the seat subframe. I think I might just get 300mm x 300mm steel plate, should be more than enough. Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 3, 2014 Author Share Posted December 3, 2014 It seems to be about 4 or 5 mm thick... Thought that was what you were after 300x300 seems like it might be about enough Quote Link to comment Share on other sites More sharing options...
ammarbm Posted December 4, 2014 Share Posted December 4, 2014 I love the Engine bay mate..Blue is my favourite theme as I have got blue in mine also ...I so want a pirates black deck mate but they seem really hard to find now Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 4, 2014 Author Share Posted December 4, 2014 Cheers bud. There's not many decks of any sort come up really... 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 9, 2014 Author Share Posted December 9, 2014 Right... Got new balljoints on (lower ones), and I've still got a bit of a creak... Not on turning the wheels though, only a slight one that seems to be when going over bumps.. I.e. When the suspension is working. Also seems to be more central in the car at the front... Any clues? Quote Link to comment Share on other sites More sharing options...
ammarbm Posted December 9, 2014 Share Posted December 9, 2014 On 12/4/2014 at 8:17 PM, dr_broon said: Cheers bud.There's not many decks of any sort come up really... How strange is that, one came up just the next morning lol Quote Link to comment Share on other sites More sharing options...
noodels Posted December 9, 2014 Share Posted December 9, 2014 Rear Engine mounting?Engine mountingsExhaust mountingExhaust joints +spring area are worth a look for squeeks 1 Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 9, 2014 Author Share Posted December 9, 2014 On 12/9/2014 at 6:12 PM, ammarbm said: How strange is that, one came up just the next morning lol Isn't it just! Quote Link to comment Share on other sites More sharing options...
dr_broon Posted December 9, 2014 Author Share Posted December 9, 2014 On 12/9/2014 at 6:50 PM, noodels said: Rear Engine mounting?Engine mountingsExhaust mountingExhaust joints +spring area are worth a look for squeeks Good call... Easy ish to check Quote Link to comment Share on other sites More sharing options...
