MC2 Project - Chassis prep
DeLaSoul
Feels a bit more like a car too. Not sure about sitting so far back as I can now really judge it! :)
As long as you haven't already fixed the seat into position you can change it once there's more interior in, well what is going back in anyway!
I can move the seat one click forward and 5 clicks back.  New pedals really dictated the seat position as they come back another 5" from the stock position.  It'll be more than drivable, just feels weird being so far away from the dashboard and even the indicators!
Ohhh. Can you drive it yet?!?!?!!
Not unless someone is pushing it along for me :)
If sitting there making noises counts then I'd say yes!
Brrrrrrm Brrrrrrrmmmmmm Brrooooom Brooomm lol
  • Like 3
That's how I feel when I get into one of those new cars that have huge dashboards and you end up 2 or 3 feet further away from the windscreen!
  • 1 month later...
Time for a quick update (not a lot happening, work it getting in the way)
New radiator has arrived, doesn't fit but I'll soon sort that :)
Need to cut off the stock lower mounts for the radiator, unbolt the air con rad mounts and reweld.  The pins for the top will also have to be cut off and new mounts made on the sides of the rad.  Not something I'm going to attempt but I know someone who can help
This will also pull the rad forward to give more clearance to the manifold
Next job, sort the dials.  I know the stock fuel gauge will not work with the new fuel cell, so need somewhere to fit the new gauge.  Why not use the old location? [smash.gif]
Stripped down the casing, and a quick skim with the dremmel and the gauge fits the front panel
Time to make it fit the back part, clear off everthing in the way
Mark out roughly where the gauge will end up
Not my finest dremmel moment, but it will do for now.
Cut the circuit board to clear.  Luckily, I am only effecting the original fuel gauge connections, nothing I can't bypass
And then time to clean, reassemble and re-glue the housing back together
Saves having a dead dial and another stuck on the dash!
