Maz's Pirates Black VTI Deck.. Sold.. Project Closed..
ammarbm
ye i managed to get the top mounts off by someone pushing down on top mounts and someone else undoing the top mount itself
Hmm that's interesting.. I am gonna get a spare set of standard shocks though as I wanna keep a standard set ready in case I have to swap back :)
Good to have a spare set!
On another note maz... Your fog lights... I'm going to buy them, but have you got any photos of the fog brackets fitted without the shroud fitted?
Just so I can see if it's an easy fit or if it's going to be fiddly :)
I'm going to have a set of those spare soon. :P
How do you hold the spring then? Does it not shoot out once the mount is removed?
With ur foot lol! They ain't that compressed well mine never have been anyways!
Yeah I spent time prepping the grill.. Rubbed it first with the soft sanding block I got. Then I used wet 240 grit sandpaper and that cleaned it up nicely.. Used plastic primer on it. Three layers. Then wet sanded that with 1200 grit.. Did three layers of color and three layers of lacquer.. Wet sanded lightly with 1200 grit again.. Then compound and polish an and it turned out very smooth and shiny.. No lacquer runs :).. Hoping to do the same to the lip kit :)
Nice, what compound and polish did you use?
Yeah I found a set for £20 from breaker..Not too bad a price :)
Look at the top of page 6 mate..Is that photo what you are after?
