KiNK43 Posted January 8, 2016 Share Posted January 8, 2016 Can't necessarily explain the low oil pressure light. Apart from the fact the engines stalled. So if you've say disengaged clutch once engone cuts out oil pressure will drop instantly.As for the main problem cutting out. Sounds like a faulty ignitor. Although they are available separately. It's usually a case of replacing the dizzy.Usually will throw code 15. Ignition output signal or something similar.Seem to fail around the 100k mile mark for whatever reason. Read that code first see what it's saying before jumping to any conclusions but likely the dizzy from what you've said. 2 Quote Link to comment Share on other sites More sharing options...
snakey135 Posted January 8, 2016 Author Share Posted January 8, 2016 Good shout lads.. I'll get the codes in my lunch break n see what's poppin!... Now to find the guide on here which says how to get the codes lolCheers fellas Quote Link to comment Share on other sites More sharing options...
snakey135 Posted January 8, 2016 Author Share Posted January 8, 2016 Got the code and it did indeed come back with code '15 - ignition output signal'My mate is saying it might just be the ignitor module, could this be the case? Quote Link to comment Share on other sites More sharing options...
Chandler Posted January 8, 2016 Share Posted January 8, 2016 thought that might have been the case. told you @KiNK43 would sort it Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted January 8, 2016 Share Posted January 8, 2016 Just had a little catch up one ere because I have been slacking to visit the forum lately, so you're not the only mate Sounds awesome with that decat and those new hoses look well nice! I hope you get that problem sorted out Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 9, 2016 Share Posted January 9, 2016 Yeah man its the ignitor. Can buy them separate and repair the dizzy. Just more often than not the dizzy is replaced. Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted January 10, 2016 Share Posted January 10, 2016 Yep i had the same n dide a new dizzy n problem sloved Quote Link to comment Share on other sites More sharing options...
snakey135 Posted January 13, 2016 Author Share Posted January 13, 2016 Hey lads, and Tom! Cheers for the help and advise, I've decided to take her off the road for a bit to get some bits done on it... The dizzy problem was so bad it was cutting out every 5 mins or so and sometimes not starting at all!.... Needs a few other bits doing too so best not to run it into the ground and liven her up a bit! 1 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 13, 2016 Share Posted January 13, 2016 Good man. Sort that fooking deck out good and proper Quote Link to comment Share on other sites More sharing options...
Chandler Posted January 14, 2016 Share Posted January 14, 2016 ye get it done mate take your time Quote Link to comment Share on other sites More sharing options...
