- Last week
- Earlier
Know the feeling about being lazy, 😂 Are you moving far bud?- 921 replies
- honda civic mc1
- honda civic aerodeck
- (and 7 more)
Thanks, it's an alpine unit so even though it's new I think it fits with the 90s-ish vibe of the car. It's no doubt the brand I would've gone for if I had the money back in the day haha. It has RGB lighting so I can change it to march the dash which is nice (I'm being picky but I don't like it when the colours don't match!) The car came with a pretty retro looking JVC CD player but only 1 channel was working for some reason and it had a really shoddy aftermarket Bluetooth kit (calls only) with wires bodged in all over the place so I thought it was best to bin it all and fit something new I did consider not bothering with a head unit but even though the build leans towards track car, I've been in cars which are totally stripped before and whilst you might be able to get an extra 20kg out by removing the heater, stereo, half the dash, etc, it makes the car unusable for anything other than trailering really Yes he basically said he managed to get it all down the side by sticking a pair of long noise pliers through the popped out hazard switch and holding the cables out of the way of the head unit I've stripped everything from the front seats back and deleted the air con (it was broken anyway) so I'm not even sure I'll be able to hear the radio over the rattling but that's about the extent of the weight reduction for now. It should be a lightweight chassis anyway as it doesn't have a sunroof or other luxury features 😂 -
- 2 replies
- 1
- honda civic mb
- general
(and 4 more)
Tagged with:
Got this photo from my father in law this morning that he got the head unit in in about 5 mins on the first try, always the way 🙃 -
More progress MB6 dash installed and MB6 cluster fitted Modified the centre console slightly (basically just removing the tray in front of the gear stick) to accommodate the shifter box Cut a hole in the back of the glovebox and mounted the ECU inside Installed a steering wheel boss and OMP 300mm wheel Unfortunately I wasted a couple of hours trying to get the head unit to fit in the dash as I was struggling with all the spiders web of cables behind so I couldn't get it rolling today 🥲 but it's a marathon not a sprint! -
Meant to update this! Got the ABS fault sorted, was right rear abs sensor. Was supposed to be a 10 min job to remove/fit, only one 10mm bolt! Said bolt was rounded to he'll, so took time to get that out. Then the sensor itself wouldn't come out! In the end had to remove brake caliper, caliper carrier and brake disk so I could hammer the sensor out! What a faff. New one fitted, all back together and abs light now gone!😀 Also had her in for her MOT which she failed. Didn't fail on much tbh, handbrake efficiency, broken o/s/f coil spring. Couple of advisories for o/s/f ARB drop link and a tyre slightly perishing. Got everything done except the tyre as I'm gonna replace all 4 soon anyways so she now has a clean bill of health. Still driving nice, and love her to bits!
Me being lazy! Lol Don't think she'll need anything tbh, maybe the usual handbrake adjusted but other than that hoping she passes when I get her booked in. In the middle of moving house again so will get her seen to after that. Got a mate who has a recovery vehicle and his rates are decent so he'll be moving her to her new garage in October🙂
- 921 replies
- 1
- honda civic mc1
- (and 7 more)
- 5 replies
- electrical
- honda civic mb6
- (and 3 more)
Thanks for that - totally missed your reply - thats great info Since this post I found the mistake and bought a set of MGZS 180 front 282mm calipers and carriers second hand for £80 delivered which wasn't bad at all really. The seals etc looked ok but they were a bit grotty so we soaked them in evaporust and then my father in law stripped them down and painted them in high temp silver and they look a lot better now. Still not got any pads or discs yet but that will come in time... A running engine first would be a good start 🙃 (see my build thread for the fun i've been having there...) I definitely plan to change to rear discs at some point but as it's quite a lot of work/parts required so I'm going to see how I get on with rear drums to start with until budget allows (currently diverted for more important topics) - whilst it doesn't look or sound very good it's not as bad as you might expect... -
Cheers mate, loving it to be honest.. It's dead comfy for munching miles, if not quick. Totally the opposite to the deck.. Sat up tall, soft air springs, and lazy drive, instead of low down, stiff and engaging. Got the best of both worlds now 😂
